Dometic AC/HeatPump/Furnace Troubleshooting
Hi All,
Does anyone know if the new Dometic Thermostat CCC 2 3314082.011 will work with the old Dometic Duo-Therm Penguin 630516.321? We're having trouble with the AC/Heat Pump/Fan feature but the old Comfort Control 5-button worked with furnace still. In trying to troubleshoot, must have touched something on back of thermostat that shorted it out and now have no furnace either. Have tried the reset (mode and zone while turned off and turning to on) multiple times to no avail. Have checked all fuses and breakers and have correct voltage. Don't want to order an old thermostat version if we end up needing a whole new AC unit any way so trying to see if the new CCC 2 will work with the old AC unit?
Thanks!
Tiffany
2005 30 Safari Bunkhouse
I'm restless. Things are calling me away. My hair is being pulled by the stars again. -Anais Nin
