Sounds like you already have solar panels on your trailer, correct? The question here is how to power your 120v outlets from solar?
If that's what you're after, then you will need to install an inverter.
The solar system will supply DC power which is used to recharge your
12v battery bank. It will not directly supply power to your 120v AC outlets. For that you need an inverter.
The inverter has supply leads which bring
12v DC power from the batteries. With that
12v DC input it will supply 120v AC power. The more simple inverters have a pair of 120v AC outlets on them which you plug into directly. If you want to go beyond that, you need to do some 120v AC wiring to hardwire the output side of the inverter to your outlets & circuits. This can be done by either installing a few dedicated inverter outlets or by moving a circuit from your current breaker panel to be fed from the inverter.
If your goal is to get all the outlets running off of the inverter, then you're looking at installing a transfer switch so that you can go from shore power to inverter power. Not an easy project.
When you say 'all the outlets' are you talking about the outlets where things like the microwave are plugged in? Or just the outlets for little things like lights and phone chargers?
To run all the circuits from an inverter and include everything you'll need a suitably sized inverter, and this would require a suitably sized battery bank, and this would require a suitably sized solar array to recharge the batteries. What I'm getting at here is that you're going to have to calculate just what you plan to run from the inverter and then size everything downstream from it correctly.
It would help if you could be more specific on what you're trying to accomplish here.
