Old 09-04-2024, 01:26 PM   #1
69SoulShine's Avatar
Bluffton , South Carolina
DC to DC Charger wiring on new TV
I picked up my New F-350 King Ranch yesterday. Woo hoo! Now I have to wire it for my Victron 30 amp DC to DC charger. It was previously wired by others with a 1/0 positive cable from battery to a Anderson plug at bumper. And grounded to the frame near the bumper from The Anderson plug.
My question is should I go back with the ground running through the frame or would it be better to run a negative wire back to the battery? I’m also considering downsizing the wire to #2. from what I understand that should be sufficient for the 30 amp charger?
Thanks.
69SoulShine is offline   Reply With Quote
Old 09-04-2024, 04:34 PM   #2
2022 25' Flying Cloud
Tualatin , Oregon
I have a Renogy 40A DC-DC and used 4ga cable off the positive of the truck battery to an Anderson connector at the tailgate. Used the truck frame for the ground connection to the Anderson connector.
I'm happy with the performance.
Steve
TitusNW is offline   Reply With Quote
Old 09-05-2024, 06:24 AM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Grounding only to the frame is not a great idea for something like this. It might work well sometimes and not so well other times. Best to run the ground wire. Best solution is to do both ....(run the ground wire and hook to the frame).
Old 09-05-2024, 07:09 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I agree that it's best to run a dedicated line for both the positive and negative.
By using the frame as the ground you're putting more load on the existing ground strap/cable serving the tow vehicle, and they are prone to corrosion and degradation over time. Problems with poor grounding is a common problem when a vehicle is having charging issues - might not be a big deal on a new truck but it can creep up on you faster than imagined, especially if you live somewhere with winter or salt spray from the coast.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 09-05-2024, 08:42 AM   #5
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
+ on using dedicated ground
69SoulShine, congratulations on your new F350!
I’m with Uncle Bob and Richard on this. I pulled 4 AWG TEMCo wire from the battery to the bumper for our 40A Renogy. I used a high temp sleeve for the front section (belt and suspenders) then corrugated plastic to the bumper.
I used a 60A MRBF fuse mounted to the battery busbar, part of the outfitter’s option. This makes for a very compact installation. Also, I pulled a single 12 ga. wire for the Renogy’s ignition signal and wired it to an Aux switch programmed to turn off when the ignition is off. This way I can chose to turn the DC-DC charger off if I ever need to.
At the bumper, I used a Trailer Vision holder for the Anderson plug with a cover. Keeps everything nice and clean.
I have read that you can experience voltage drop when using the frame as a ground, likely to Richard’s point about overloading the existing grounds. YMMV!
Good luck and enjoy your new rig!
ID:	447147   Click image for larger version
ID:	447149   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 09-05-2024, 09:15 AM   #6
2015 30' International
Escondido , CA
I also agree with running the ground to the battery but, the math was simple for the distance and 30amp, I used 6 gauge wire and was able to route it away from anything hot on my 2018 Ram 6.7.
dsatwork is offline   Reply With Quote
Old 09-05-2024, 09:30 AM   #7
2022 27' International
Poway , California
Jeff, Where did you get that frame mounted anderson mount? BTW I'm running both ground and positive 4 gauge.
Never mind, found it on Amazon, Thank You for the inspiration!
License Plates: AIRDRMM and DRMMHLR see you out there somewhere...
markuscis is offline   Reply With Quote
Old 09-05-2024, 09:40 AM   #8
1994 25' Excella
I got mine from Amazon
https://www.amazon.com/stores/page/6...o&ref_=ast_bln
Richard
11018
Old 09-05-2024, 11:51 AM   #9
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
Ground and Switched
I have your vehicle only a F-250. The rear ground short frame wire is fine as long as it is with proper size cable and a clean ground with a bolt connecting it. I verified that with voltage drop when the system was under load.
In addition I used a fused battery cable from the alternator positive post to a Blue Sea Solenoid. The other side carries the current back to the Anderson connector. I used the Ford up fitter switch #2 to control the Blue sea solenoid current back to the Anderson connector. I like to be in control of that circuit either on or off! I do not like it wired hot all the time.
The Anderson connector is mounted in a composite holder like Jeff's
Life is a Highway is offline   Reply With Quote
Old 09-05-2024, 06:46 PM   #10
Thanks everyone for the helpful info and advice. This community is great.!
Old 09-08-2024, 08:18 AM   #11
Warning in Ford’s owners manual
So while in the process of installing my dc to dc charger (truck side) I came across this warning in the owners manual. My question is has anyone had a discussion about this with someone from Ford? And what are your thoughts on this?
Old 09-08-2024, 08:50 AM   #12
jeffmc306's Avatar
McHenry , Illinois
While not a Ford, our RAM also has a BMS sensor connected between the battery and the truck’s ground cable. I connected my Renogy’s DC-DC charger’s negative cable to the stud on the BMS, not the battery. See the photo attached.
This way all the current is measured by the BMS (similar to a Victron BVM’s shunt). I think if you do the same you’ll be in line with Ford’s recommendation.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 09-08-2024, 09:25 AM   #13
Tualatin , Oregon
Attached is the setup of a 2021 F-150. When I was thinking of the path of electrons to keep the Ford BMS in the loop I considered the ground strap (with the white tag) but didn't know if the BMS would be in the loop. I opted to ground my Anderson connector to the frame and let the electrons find their own way to the battery.
Steve
Old 09-08-2024, 11:07 AM   #14
This looks like it would send it through the BMS.
Old 09-08-2024, 11:09 AM   #15
One more concern that I see in the owners manual mentions if the BMS sees excessive current drain it will start shutting down systems. Here's a photo of that screen.
Old 09-08-2024, 11:58 AM   #16
Tualatin , Oregon
I read those same notes before I installed my charger. You can also read the Ford forums for posts relating to "System off to save battery" and/or "low battery". It seems that many owners have issues with the OEM battery and short commutes. More unbelievable to me, it seems many put their trucks on battery maintainers overnight!
I installed my DC-DC charger Aug 2023 and have no troubles over the last 20K miles. Regarding the Ford warnings, I use the 7-pin charge line to power a wireless switch in the trailer so I can turn the charger ON of OFF from the truck. I don't have it on unless I'm rolling down the road for good alternator cooling. If the batteries are not topped off, I turn OFF the charger for road blocks or traffic jams.
Before my recent trip to Alaska I chose to replace the OEM battery with a new Interstate H7 battery. I figured why risk a big trip with a 36 month old battery. They don't build them like they used to...
It all works for me but I do try and be gentle on the alternator.
Steve
Old 09-08-2024, 02:04 PM   #17
jeffmc306's Avatar
McHenry , Illinois
Yes, that would be the same as what I did. The BMS sits between the ground wire and the battery from what I can see from TitusNW’s photo of his.
If you connect it to the stud on the top, it meets the Ford recommendation.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 09-08-2024, 05:10 PM   #18
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I agree with others who've indicated to run both + and - in close proximity to the battery. While I am no expert, I've heard of too many problems with "ground loops" (attaching ground to a point that is remote from the positive terminal). Based on the couple of pictures in earlier posts, I wouldn't hesitate to connect the ground at the vehicle chassis where the ground cable is attached from the battery. That's what I did on our GMC Sierra.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 09-13-2024, 01:06 PM   #19
Friends On The Open Road
2022 25' International
Holland , PA
DC to DC charge. - inside the trailer
Thanks all for the great dialog.
I’m looking at dc to dc charging to address the problem of having to keep propane on if I want the fridge to stay cool.
We have a two way - runs on shore power or propane.
should I
A. Replace the propane fridge with a new 12v
B. Install dc to dc charging - if so can a 50amp dc to dc put enough energy into system to run 120v fridge.
Where do I connect the power coming out of the dc to sc charger ?
Michael
TravelTales is offline   Reply With Quote
Old 09-13-2024, 02:16 PM   #20
1994 25' Excella
should I
Michael
The power output from your DC-to-DC charger goes to the same place your converter goes. It would also be the same place your solar charge controller goes if you have solar. That place is the bus bars for the positive and negative, if you have bus bars. If not, then where ever all your connections to your battery bank are.
Richard
11018
Inverter/Charger vs Inverter + Charger Vernation Batteries, Univolts, Converters & Inverters 19 01-03-2024 04:14 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
Inverter Charger wiring questions mello mike Batteries, Univolts, Converters & Inverters 13 03-09-2010 08:11 AM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
