Old 12-10-2020, 01:38 PM   #1
2018 30' International
Southern Pines , North Carolina
DC-DC chargers?
Any consensus on the best brand and size for a dc-dc charger. Ideally something that would fully charge two the trailers AGM's during a 4-5 hour drive. Is that realistic? TV is a 6.7 F250 with the heavy duty alternator and dual batteries.
NC-Serenity is offline   Reply With Quote
Old 12-10-2020, 01:57 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
best OEM is victron energy
http://www.victronenergy.com
they have many different sizes to choose from
waninae39 is offline   Reply With Quote
Old 12-10-2020, 05:19 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
With your heavy duty alternator, you should do a 40 amp Renogy. That is what GMFL used on the Long Long Honeymoon upgrade. I am using the 20 amp Renogy on my whimpy F150 upgrade.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is online now   Reply With Quote
Old 12-10-2020, 06:09 PM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I've had great success with Sterling BTB charger. Lots of sizes to choose from.
https://www.sterling-power-usa.com/b...ychargers.aspx
richard5933 is offline   Reply With Quote
Old 12-10-2020, 06:34 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
The 40A Renogy is a great DC Charger.
GMFL is online now   Reply With Quote
Old 12-10-2020, 07:50 PM   #6
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
A little over a year with the Renogy 40A in my class b and it works wells. I put an on/off switch on the ignition wire so I can keep it off until I'm on the highway. That way I know my dinky 160A "heavy duty" alternator has already topped off my engine battery before supplying juice for the 2 x 100Ah lithiums.
rowiebowie is offline   Reply With Quote
Old 04-20-2021, 06:44 PM   #7
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I finally had a chance today to test out my 20A DC-DC charger. At idle, to 20A model put out 24 amps at 13.7v. This was on full batteries. I am happy with the results.
DaveP
Old 04-22-2021, 11:58 AM   #8
DaveP's Avatar
2004 28' Classic
Monument , Colorado
BTW, I found out the alternator in my truck puts out 200 amps. Not too bad. I think it is because Ford equipped this truck with a 120 volt receptacle in the back seat.
DaveP
Old 04-22-2021, 04:30 PM   #9
pjshier's Avatar
2017 27' International
Wasilla , Alaska
Orion 12/12 Isolated 18 amp test today
With batteries at 97% according to the Victron Connect App, the batteries were at 13.41v, current was 12 amps, power was 161 watts.
The Orion page showed input voltage of 13.1v and output voltage of 13.6v
All at idle. Haven't checked the wires under load to see if temps will be an issue, but i doubt i'll see much increase in temp at these relatively low numbers.
Still, very happy that current is moving in the correct direction and nothing has burst into flame.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Battery Trickle Chargers Devoman Batteries, Univolts, Converters & Inverters 4 04-06-2010 06:09 PM
Batteries, Chargers, Inverters and Wire Size amalgamator Batteries, Univolts, Converters & Inverters 0 03-24-2008 06:46 PM
Battery chargers FrenchBern Batteries, Univolts, Converters & Inverters 18 09-04-2006 10:54 AM
Micro processor controlled chargers. FrenchBern Electrical - Systems, Generators, Batteries & Solar 0 07-27-2006 01:00 PM
Battery chargers or not ??? donnall Airstream Motorhome Forums 2 12-06-2003 04:43 PM
