Converter Replacement Ground Connection
I'm replacing my converter with a Lithium capable unit and hoping to get some guidance. The negative DC output from the existing converter exits on a tiny 10 gauge wire and goes into the fuse panel as depicted in the picture below.
Can I just run the negative output for the new converter on a new 4 AWG cable to the negative bus bar at the DC distribution box. Or is there something special about the connection at the fuse panel?
New unit is a PD9160ALV if that matters.
