converter install
I've got a 2018 Flying Cloud 27 with a pair of lead-acid batteries. I'm replacing them with Lithium (LiFePo4) batteries. The present converter is a WFCO WF-8955 which won't work with lithium. So I thought I'd replace it with a 'drop in' converter of the same dimensions and amperage but that will work with lithium.
I'd like to replace it with a WF 8955 AD-MBA. Do I just push the thing in, screw it down, attach the DC wires, attach the Breaker side AC wires, all grounds and neutrals, and be done with it?
Or am I supposed to put the MBA unit inside the metal case from the original unit?
Praat Afrikaans of hou jou bek.
