Old 05-15-2021, 04:31 PM   #1
2017 19' International
Tallahassee , Florida
Converter fan running
Out on a trip, and yesterday when we set up the camp the converter’s fan started running and, hours later, was still at it.
I assumed two options: blown converter or bad battery (perhaps batteries).
Since the batteries were showing some age, this morning I tracked down some replacements and went ahead and swapped them out (a parking-lot operation outside an auto parts).
Now in a new campsite. Plugged in the trailer and ... converter fan still running.
I can see how maybe the converter is doing double duty bringing the new batteries up to a full charge and might need the fan to keep its innards cool.
Is that likely?
I hate to have to replace the converter, especially on a trip.
WhereStream is offline   Reply With Quote
Old 05-15-2021, 04:40 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Two things.
#1 The batteries were Lilly bad if they were flooded lead acid batteries. So the converter might have been pushing extra hard to charge a battery with a bad cell or cells and also support the DC loads of the trailer.
Easy way to check the converter is to disconnect the batteries and plug the trailer into shore power. If the DC loads are supported (i.e. lights, fans, ect) then the converter is likely fine.
#2 New batteries from Auto Parts store are probably charging up and given some time the converter should settle down. If you need to replace the converter on the road it will not be a hard job and can likely be done in less time than it took you to swap the batteries.
Old 05-15-2021, 08:14 PM   #3
Thanks, GMFL.
When I get a chance, I will disconnect the batteries and see what floats.
Old 05-16-2021, 10:50 AM   #4
2018 30' Classic
Traverse City , Michigan
Does the inverter have to be on to charge the batteries. Just had ours worked on and this morning the battery is low (plugged into shore power).
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 05-16-2021, 09:54 PM   #5
I did not get a chance to disconnect the batteries before we had to hitch up and head out.
The converter fan never stopped blowing, and the battery voltage, per the push-the-button-on-the-wall thing, was reading 12.4 volts, barely up from 12.3 volts earlier.
Bear in mind that it usually reads 13.6 volts when shore power is attached.
So, not a hopeful situation, but ... down the road we go.
After a little more than two hours on the road we stopped for lunch. I went in to check the battery voltage ... now 12.6. The Ford was moving the charge in the right direction.
By the time we got to our campsite, another hour later, the voltage reading was 12.9.
Plugged in shore power and ... no noise, no fan roaring.
Now, at the end of the day, it is showing the usual 13.6 volts.
Business as usual.
It appears the new batteries needed some charging before the converter could settle down.
Or maybe something else ... batteries and battery charging remain a bit of a mystery to me.
Old 05-17-2021, 05:25 AM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
You need to check and make sure you do not have a loose wire on the converter or on the DC distribution bus in the front of the trailer
Converter fan running constantly Dlat Batteries, Univolts, Converters & Inverters 12 06-20-2020 12:16 PM
Converter fan running... batteries fried... batteries replaced... fan still running! hollycwright Batteries, Univolts, Converters & Inverters 2 04-27-2020 03:41 PM
Converter fan running constantly! sjski Electrical - Systems, Generators, Batteries & Solar 11 08-12-2019 11:02 AM
Converter cooling fan running all of the time. fclewis Member Introductions 5 06-08-2018 09:05 AM
Converter Fan Running Continuously tjwoods1 Batteries, Univolts, Converters & Inverters 0 04-02-2018 06:58 PM
