Old 10-03-2003, 06:34 AM   #1
Mike76251's Avatar
Lightbulb Control Panel fix!
My control panel had three bulbs in it that were pulling too much current through the solder lines on the board.
The solder actually melted on the main power line on the board.
This meant that nothing worked on my control panel.
(BTW: It takes alot of current to melt solder: that current comes from your battery)
I pulled the board out and re-soldered the broken trace and put LEDS in the place of the bulbs.
That was ten years ago and the LEDs still shine bright.
They take alot less energy than the original bulbs and don't run your battery down.
If your old control panel is on the lamb this might be the fix.
Mike
Mike
Mike76251 is offline   Reply With Quote
Old 10-03-2003, 03:35 PM   #2
71tradewind's Avatar
Good info to have Mike ,Thank you !
71tradewind is offline   Reply With Quote
Control panel wanted... Rick Electrical - Systems, Generators, Batteries & Solar 0 09-03-2003 03:40 PM
Control Panel Problem uwe Electrical - Systems, Generators, Batteries & Solar 1 06-16-2003 02:07 PM
GM a/c control panel rdm Mechanics Corner - Engines, Transmission & More... 5 11-11-2002 07:30 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
