Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-08-2018, 08:08 AM   #1
stromboli's Avatar
2018 33' Classic
Beacon Falls , Connecticut
Classic reverse lights on
Last evening, I noted that my back up lights were on while parked in the driveway ... no shore power. I contacted JC customer service and was walked through three steps to troubleshoot my situation. It turned out to be moisture in the 7-way extension (to accommodate hitch). Thank you to JC. Everything is air drying now. As soon as I unplugged the lights went out.
Regards,
~Chip
stromboli is offline   Reply With Quote
Old 05-08-2018, 11:16 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You must keep your powder and wiring dry... WD40 will dissipate the moisture... but it will also attract dirt..
So, I use 'electric contact cleaner'... then apply some Dielectric Grease... no mo prob.
Oh.. hand the end of the cable (umbilical)/7way wiring, under the Propane cover.. it is usually dry there..
Always leave the 'end' of the connector hanging toward the ground.. but do NOT get it in the dirt !! or mud!!! If you do, clean as above and re-protect.
Peace and Blessings..
Channing
WBCCI# 30676
Brake lights, turn signals, reverse lights not working! HELP! blogworthy Argosy Motorhomes 6 04-16-2018 06:21 PM
Reverse/ Back-up Lights on a 1950's trailer worldinchaos Lights - Interior & Exterior 2 05-10-2011 08:55 PM
Reverse lights Stay on when AS is plugged in! shermantic Lights - Interior & Exterior 3 02-01-2009 10:15 PM
Reverse lights stuck on. Jack wont work StAlphonzo Electrical - Systems, Generators, Batteries & Solar 3 07-04-2007 07:56 AM
Reverse lights till Electrical - Systems, Generators, Batteries & Solar 5 09-11-2004 04:29 AM
