Old 08-06-2018, 04:55 PM   #1
TetonStreamer
Teton Stream's Avatar
2021 27' Flying Cloud
Delaplane , Virginia
Charging trailer while connected to TV
If the trailer is plugged into shore power and is also connected to Tow Vehicle does that provide the ability to simultaneously charge the TV battery? Does it prevent any draw from the TV battery?
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 08-06-2018, 05:01 PM   #2
Retired.
. , At Large
It depends on the tow vehicle. Many have charge lines that are always live, some have relays that disengage the charge line when the engine is off.
Old 08-07-2018, 06:12 PM   #3
2011 22' Sport
Portland , Oregon
If you switch to using lithium batteries and a lithium charger then this is actually something you want to avoid, you want to avoid over charging your TV battery for the opposite problem. But as overlander63 states, it really depends on the tow vehicle on if the charge circuitry is always connected or not, there is nothing in the circuitry to prevent power flowing the "wrong direction".
SilverHouseDreams is offline   Reply With Quote
Old 08-08-2018, 09:20 PM   #4
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
as others have posted elsewhere, i got a victron orion DC-DC converter.
that ensures both one way feed and that the output is suitable for Lion
waninae39 is offline   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 08:12 PM
Freshwater tank filled up while connected to city water Native143 Fresh Water Systems 16 07-01-2018 03:15 PM
Trailer battery not charging while towing??? ghamr Electrical - Systems, Generators, Batteries & Solar 19 08-28-2014 03:35 PM
Battery charging when connected to shore power. Wingeezer Batteries, Univolts, Converters & Inverters 3 07-15-2011 10:12 AM
Charging time for battery while towing John Electrical - Systems, Generators, Batteries & Solar 2 12-23-2002 03:14 PM
