Old 07-28-2021, 08:01 PM   #1
Belmont , Michigan
Question Champion Inverter Generator
Looking to purchase a generator for a little boon docking. I have a 2017 19Ft Flying cloud, 30 Amp. Have been looking at 'Champion Power Equipment 200988 4500-Watt Dual Fuel RV Ready Portable Inverter Generator, Electric Start' for around $950. Any opinions on size and make/model would be greatly appreciated. Thanks, James
Razzordude is offline   Reply With Quote
Old 07-28-2021, 08:17 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
My opinion is that it is heavy to lug around @100lbs but will power your trailer no problem. Champion seems to have a solid following. Probably a little more output than you really need @3500w continuous output for a single AC 19’, but then again every 1000’ of elevation will reduce output by 3% if you plan to travel out west. Price is right
Those specs are hard to beat for <$1000 buckos if it lasts. Propane certainly eliminates all the problems with carburetor maintenance.
wulfraat is offline   Reply With Quote
Old 07-28-2021, 09:05 PM   #3
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
I own the gasoline powered version of that generator and it’s fantastic. It’s quiet and it works well. As wulfraat said, it’s a bit heavy but only six lbs. heavier than the 3,400W model. It easily powers my 30A system, even in high altitudes. I added the carburetor jet for 6,000+ feet of elevation, and the unit runs smoothly. Remote start is a great feature too!
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 07-28-2021, 09:15 PM   #4
2017 25' International
West Lake Hills , Texas
I own the Champion 2400. Runs one AC with EasyStart. The generator starts on the first pull. Dual fuel. Quiet. 40 lbs I think. Plenty of generator but without the weight.
Fungus is offline   Reply With Quote
Old 07-30-2021, 02:43 PM   #5
Belmont , Michigan
Thanks 🙏🏻
Thanks for the info….very helpful.
Old 07-30-2021, 02:45 PM   #6
Belmont , Michigan
Thanks for the info.
Anyone own the Champion 3500 watt inverter generator? FCStreamer Generators & Solar Power 44 09-18-2018 12:18 PM
2000 W Inverter Generator - Champion vs. Honda DMT Generators & Solar Power 9 04-04-2013 08:21 PM
Champion Inverter Generator moosetags Generators & Solar Power 1 10-27-2010 09:06 PM
