05-24-2022, 05:58 PM
2022 30' Flying Cloud
DFW
Champion Dual Fuel Mod
I have a Champion 2200w dual fuel generator that I'm trying to modify to allow connectivity to the LP port on the rig. To do so, you need to remove the stock regulator that comes with the generator for propane use. This seems to be a pretty popular mod.
The issue I'm running into is that it appears the regulator was secured with red adhesive from the factory and it won't budge. Anyone have any ideas on how to remove it?
05-24-2022, 06:36 PM
2022 28' Pottery Barn
Varies
Skip the modification for the low-pressure port and run it off your regular propane tanks(s) with a Y connector and a longer hose.
05-25-2022, 05:35 AM
2021 19' Bambi
Latham
, New York
I have a Champion 2500. Just get a longer hose with the fittings on it.
Save the short hose with the regulator for using the generator away from the AirStream.
05-25-2022, 07:48 AM
2019 27' Globetrotter
McHenry
hawkspur, we have the Champion 3400 dual fuel that I run off the Airstream low pressure port.
I split the two units and put quick connect fittings on the regulator because I wanted to retain the tank operation for home. I use a 12’ LP extension hose between the trailer and generator. I found the parts list on another forum thread. Search for Champion 3400 and you should find it
It’s an easy change and works great!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
05-25-2022, 11:15 AM
2018 23' International
Pensacola
, FL
Yes, that is an easier option. The red stuff you see is a sealant like Permatex, but for natural or propane gas to minimize the chance of a leak. If you have muscle, you can torque it off if you really wish to.
05-25-2022, 01:56 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Do not remove the regulator that connects to the engine. It is an ultra low pressure regulator designed to reduce already regulated 11-13 inches of water column to .5 inches (one half inch of water pressure). Just connect your genny feed hose directly to the low pressure port on the tongue of your trailer. I prefer the 3/8 brass quick connects with the black plastic bag valve handles.
guskmg
05-25-2022, 03:20 PM
DFW
This is more or less what I'm trying to do, but I haven't had any luck separating the regulator from the rest of the assembly
05-25-2022, 03:32 PM
2019 27' Tommy Bahama
Foothill Ranch
I too have a Champion Dual Fuel. The Champion-supplied LP connector must be used (it electronically checks that it's in place or it won't fire). So utilizing that portion, I'm not following how you take advantage of the AS built-in quick connect port on the A Frame hitch. Color me dumb, but what do you mean by "I split the two units and put the quick connect fittings on the regulator?"
05-25-2022, 07:44 PM
McHenry
No worries Mark, no name calling here!
The Champion regulator has two parts; you need to split them and install a 1/8” FPT to 1/4” FPT brass connector then a 1/4” quick connect male fitting on the larger pressure reducing valve. I used a 12’ LP extension hose to connect to the Airstream low pressure port on the road side of the A-frame behind the battery box. See photos below; some were from another forum member’s post.
Hope that helps!
2018 FC23FB
WBCCI# 10258
RETIRED!
06-14-2022, 08:11 PM
2018 27' Tommy Bahama
2016 23' International
Peachtree City
, Georgia
Hope that helps!
Thanks for sharing the process and parts list! It made for an easy ordering and modification.
06-15-2022, 05:11 AM
Pensacola
, FL
It is a red sealant for gas and just very tight to keep the gas from leaking. Just use manpower to wrench it off.
06-15-2022, 07:34 AM
Peachtree City
, Georgia
Also, I see what you did here; another great idea to incorporate for home use.
I currently have my gas oven out because I’m waiting for my countertop to be installed. I wanted to run the generator (propane function) to cool things off and create a cooler work environment.
I already made the modification changing the generator to use the AS quick connect supplied gas. Using the modification above for “home use” allows me to still run my generator as originally designed with a stand alone propane tank until my oven/AS gas line is back operational.
Again, thanks for sharing.
06-16-2022, 07:59 AM
McHenry
Colossus, glad you found the home use feature handy. We upgraded our home’s power panel to 200A because the old one was out of slots. Doing so allowed us to add a generator interlock and an outside 30A receptacle box.
Flip the main breaker to Off, flip the interlock 30A breaker On, connect the generator and chose which circuits inside you want to run. This was a selling point to the DW when choosing the Champion dual fuel generator since we can use it home and away.
We have two 20# tanks for the grill plus the two 30# tanks from the Globetrotter so we could ride out a lengthy power outage if necessary.
2018 FC23FB
WBCCI# 10258
RETIRED!
06-17-2022, 01:01 PM
Peachtree City
, Georgia
That’s awesome!! Definitely taking advantage of the generator usage along with the benefits of having a dedicated 30A at home for the RV. Well done.
Bookmarking this post, I’ve been having a hard time selling my DW on the cost of adding a receptacle for the AS and Tesla. We’re out of space in the panel as well, this may just be the information needed to get the nod. Lol
06-17-2022, 02:17 PM
McHenry
Just to clarify, my 30A receptacle is the generator feed into the home AC panel. I have not installed a dedicated 30A circuit for the trailer. We park our Airstream on the side of the garage, the farthest away from the panel. Given the cost of copper today, that one got put on hold!
2018 FC23FB
WBCCI# 10258
RETIRED!
