07-23-2017, 04:35 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Can you ID this Fuse?
After buying our AS I found this fuse in a cabinet. I don't know what it is used for and there was no ID on the box in which it was located.
Can anyone ID this fuse and tell me where it would be used? It is 12V10W.
Thanks!
07-23-2017, 04:40 PM
Sag Harbor
, New York
Looks like a standard 10 watt 12-volt fuse that fits in a standard inline fuse holder. If you think it relates to your AS I would suggest buying a small box of them at the auto parts store. [5 or so]
It probably does not go to your lift jack, but you might want to find that inline fuse near the jack head, and make sure you have extras. This is often a Slo-blow 30 amp, and threads on this type are here:
https://www.google.com/search?q=Slow...com&gws_rd=ssl
Your jack may take a different fuse BTW.
Your owner's manual should have most of the fuses listed in the back in the Specifications section. No harm in buying a bunch of extras. Amazon has generic fuse assortments as collections for not much cost. Good to have extras when needed.
Good luck!
Peter
07-23-2017, 04:44 PM
Retired.
, At Large
Thanks!
I'm pretty sure it's not a fuse. Check your fridge for a spot where a light bulb would go.
07-23-2017, 04:50 PM
diesel maniac
Airstream - Other
Tucson
, AZ
Yes that is a 12 volt incandescent lamp, common to the ones that used to be in overhead dome lights. Every VW had one of those in the dome light. A fuse is rated in amps, lamps (or bulbs if you must) are rated in watts.
07-23-2017, 04:55 PM
Tavares
So you think it's a light bulb. I'll check the fridge tomorrow. I thought is was a too big to be a fuse but wasn't sure.
Thanks!
07-23-2017, 05:00 PM
Tavares
Good luck!
Peter
It is not the jack fuse. I just went through an ordeal finding 30A slo blo fuses so I know what they look like. This is much bigger in dia. than the 30A fuse. It was suggested that it might be a light bulb for the fridge. I'll check tomorrow.
But thanks for the suggestions!
07-23-2017, 05:28 PM
1982 31' Airstream 310
champaign
It's definitely a 12v light bulb, just like the one I replaced in my fridge.
07-23-2017, 05:35 PM
Sag Harbor
, New York
Good to know thanks!
07-23-2017, 05:43 PM
champaign
I had never run across one before until replacing the one in my fridge....it looks very similar to a glass fuse
07-23-2017, 09:05 PM
2007 22' International CCD
Corona
That's a European style light bulb, not a fuse. It fits in a pair of clips or springs on each end. The comments about bulbs specified in volts and watts is absolutely correct.
07-23-2017, 09:21 PM
diesel maniac
Airstream - Other
Tucson
, AZ
Yep pretty sure my old Mercedes diesel has them in the dome lights too
07-23-2017, 11:01 PM
2013 25' FB Flying Cloud
Longmont
Thanks!
And an interesting fact about many RV fridges: The service manual for my fridge says the light bulb is sometimes turned on for the purpose of heating the inside of the fridge! Here's why: In cool conditions, it could go a long time without running the cooling system. Then the freezer compartment would start to thaw. So they use a timer and if it has been too long without running the cooling, they turn on the bulb so the fridge compartment will warm up. That triggers the cooling. (this is in the service manual for the Dometic RM3762 that came standard in my 2013 25FB)
By the way, you can find an LED to replace that one when it burns out, but because of the heating function, an LED is not such a good idea.
07-24-2017, 10:29 AM
Tavares
It is most definitely the bulb for the Dometic fridge. I checked it this morning and it is a direct replacement for the bulb that is in there now.
Thanks for helping me ID this item!
07-24-2017, 10:30 AM
Tavares
This is another thing I did not know. If I live long enough maybe I will be "one day smart" like the PA Dutch folks are fond of saying!
07-24-2017, 11:25 AM
Corona
The other saying is "Too soon old, too late smart..."
07-24-2017, 11:38 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
That bulb also goes in the wardrobe closet light fixture.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
07-24-2017, 12:34 PM
2016 26' Flying Cloud
Southlake
The proper name is "festoon" bulb. Very common on German cars.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
07-24-2017, 03:09 PM
Tavares
Just for informational purposes for others, this bulb is not used in the wardrobe closet on my 2009 International FB. The light fixture used in the closet is the same as the one in the shower and the front storage compartment.
Of course other AS are different!
07-25-2017, 09:56 AM
1969 31' Sovereign
McCall
, Idaho
Light bulb!
07-25-2017, 11:23 AM
I'm In
, Kentucky
Also common on the bow mounted red/green navigation light on boats. It's fairly common in the dome light of many brands of cars, foreign and domestic. Expensive little buggers too.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
