Old 07-23-2017, 04:35 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Can you ID this Fuse?
After buying our AS I found this fuse in a cabinet. I don't know what it is used for and there was no ID on the box in which it was located.
Can anyone ID this fuse and tell me where it would be used? It is 12V10W.
Thanks!
Name:	IMG_0979 2 2.jpg
Old 07-23-2017, 04:40 PM   #2
Sag Harbor , New York
Looks like a standard 10 watt 12-volt fuse that fits in a standard inline fuse holder. If you think it relates to your AS I would suggest buying a small box of them at the auto parts store. [5 or so]
It probably does not go to your lift jack, but you might want to find that inline fuse near the jack head, and make sure you have extras. This is often a Slo-blow 30 amp, and threads on this type are here:
https://www.google.com/search?q=Slow...com&gws_rd=ssl
Your jack may take a different fuse BTW.
Your owner's manual should have most of the fuses listed in the back in the Specifications section. No harm in buying a bunch of extras. Amazon has generic fuse assortments as collections for not much cost. Good to have extras when needed.
Good luck!
Peter
Old 07-23-2017, 04:44 PM   #3
Retired.
. , At Large
Thanks!
I'm pretty sure it's not a fuse. Check your fridge for a spot where a light bulb would go.
Old 07-23-2017, 04:50 PM   #4
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Yes that is a 12 volt incandescent lamp, common to the ones that used to be in overhead dome lights. Every VW had one of those in the dome light. A fuse is rated in amps, lamps (or bulbs if you must) are rated in watts.
ITSNO60 is offline   Reply With Quote
Old 07-23-2017, 04:55 PM   #5
Hans627's Avatar
Tavares , Florida
So you think it's a light bulb. I'll check the fridge tomorrow. I thought is was a too big to be a fuse but wasn't sure.
Thanks!
Old 07-23-2017, 05:00 PM   #6
Hans627's Avatar
Tavares , Florida
Good luck!
Peter
It is not the jack fuse. I just went through an ordeal finding 30A slo blo fuses so I know what they look like. This is much bigger in dia. than the 30A fuse. It was suggested that it might be a light bulb for the fridge. I'll check tomorrow.
But thanks for the suggestions!
Old 07-23-2017, 05:28 PM   #7
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
It's definitely a 12v light bulb, just like the one I replaced in my fridge.
mayco is offline   Reply With Quote
Old 07-23-2017, 05:35 PM   #8
Good to know thanks!
Old 07-23-2017, 05:43 PM   #9
mayco's Avatar
I had never run across one before until replacing the one in my fridge....it looks very similar to a glass fuse
Old 07-23-2017, 09:05 PM   #10
2007 22' International CCD
That's a European style light bulb, not a fuse. It fits in a pair of clips or springs on each end. The comments about bulbs specified in volts and watts is absolutely correct.
Old 07-23-2017, 09:21 PM   #11
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Yep pretty sure my old Mercedes diesel has them in the dome lights too
Old 07-23-2017, 11:01 PM   #12
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Thanks!
And an interesting fact about many RV fridges: The service manual for my fridge says the light bulb is sometimes turned on for the purpose of heating the inside of the fridge! Here's why: In cool conditions, it could go a long time without running the cooling system. Then the freezer compartment would start to thaw. So they use a timer and if it has been too long without running the cooling, they turn on the bulb so the fridge compartment will warm up. That triggers the cooling. (this is in the service manual for the Dometic RM3762 that came standard in my 2013 25FB)
By the way, you can find an LED to replace that one when it burns out, but because of the heating function, an LED is not such a good idea.
SSquared is offline   Reply With Quote
Old 07-24-2017, 10:29 AM   #13
Hans627's Avatar
Tavares , Florida
It is most definitely the bulb for the Dometic fridge. I checked it this morning and it is a direct replacement for the bulb that is in there now.
Thanks for helping me ID this item!
Old 07-24-2017, 10:30 AM   #14
Hans627's Avatar
Tavares , Florida
This is another thing I did not know. If I live long enough maybe I will be "one day smart" like the PA Dutch folks are fond of saying!
Old 07-24-2017, 11:25 AM   #15
The other saying is "Too soon old, too late smart..."
Old 07-24-2017, 11:38 AM   #16
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
That bulb also goes in the wardrobe closet light fixture.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 07-24-2017, 12:34 PM   #17
2016 26' Flying Cloud
Southlake , Texas
The proper name is "festoon" bulb. Very common on German cars.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 07-24-2017, 03:09 PM   #18
Hans627's Avatar
Tavares , Florida
Just for informational purposes for others, this bulb is not used in the wardrobe closet on my 2009 International FB. The light fixture used in the closet is the same as the one in the shower and the front storage compartment.
Of course other AS are different!
Old 07-25-2017, 09:56 AM   #19
1969 31' Sovereign
McCall , Idaho
Smile
Light bulb!
supercubep is offline   Reply With Quote
Old 07-25-2017, 11:23 AM   #20
Rich W's Avatar
I'm In , Kentucky
Also common on the bow mounted red/green navigation light on boats. It's fairly common in the dome light of many brands of cars, foreign and domestic. Expensive little buggers too.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Dreams can come true, they can happen to you... sarasafari Interior Restoration Forum 14 05-27-2014 03:17 PM
The Can Can Can travelfables Member Introductions 3 02-01-2014 01:56 PM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
Univolt and Fuse Panel - Can Somebody take a Pic? mello mike Electrical - Systems, Generators, Batteries & Solar 11 06-30-2009 10:16 AM
Can't find the 12 volt fuse panel in my 1976 31 foot Sovereign clboyd Batteries, Univolts, Converters & Inverters 20 01-30-2009 06:02 PM
