Old 11-13-2023, 02:01 PM   #1
2021 27' Globetrotter
Carmel , Indiana
Smile Can I put the DC/DC charger in my truck instead?
I've not seen much discussion on putting the DC/DC charger within the truck vs the trailer. Any reason this would not work or is a bad idea?
I'm old and not a contortionist, which seems to be the pre-requisite for electronic upgrades in Airstream trailers. Like things simple and easy to get too. I have a cab on top of the truck and thinking of mounting it somewhere inside and running a pig tail to the bumper side that can mate with the AS.
This would also allow me to charge something besides my AS. I don't have a need as of yet, but gives me the option.
Mike
Mr Wonderful is offline   Reply With Quote
Old 11-13-2023, 02:41 PM   #2
dznf0g's Avatar
Oswego , Illinois
You can, but you will still have to be a bit of a contortionist. You'll have to pull the charge line from the 7 pin. Run a new ground wire to the charger. Run a new charge wire to the 7 pin.
Not nearly as clean as doing it inside the trailer.
I assume you're limiting yourself to an 18 amp charger.
If you are running a larger converter, you'll have to run larger wiring from the TV batt all the way back to the trailer batts (buss). In that case put it where you want, keeping in mind voltage drop from.convertr to trailer.
-Rich-
Old 11-13-2023, 02:42 PM   #3
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Mike
Victron says to locate it as close to the battery bank being charged as possible, allowing for ventilation, protection from the elements and not on top of any batteries. Voltage drop due to wire resistance might play a role here resulting in the batteries not receiving a high enough voltage to top off.
I look forward to comments from others on this.
Brian
ITSNO60 is offline   Reply With Quote
Old 11-13-2023, 03:06 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
It will work better if put in the trailer.
Bill M. is online now   Reply With Quote
Old 11-13-2023, 03:45 PM   #5
1972 25' Tradewind
St Clair County , Michigan
How much of a drop?
How much of a drop in voltage are we talking about, and is it still charging the battery(ies) as long as it's in operation?
TR Anderson
Great Lakes
TR Anderson is offline   Reply With Quote
Old 11-13-2023, 03:56 PM   #6
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
TR Anderson
Great Lakes
We'd have to know wire gauge and length in order to figure out voltage drop. It will still charge as long as the charging voltage is greater than the battery voltage. From what I have learned a LiFePO4 will need somewhere North of 14.2 volts to fully charge. So if the alternator is putting out the standard 14.4 that doesn't leave a lot of room to spare for voltage drop. Also at lower voltages it may take longer to charge.
Someone will correct me if I'm wrong but the voltage drop along the charge wire from the alternator will experience voltage drop in all cases, but the DC-DC charger will compensate for this and boost voltage output but if the DC-DC is too far away from the battery the boosted voltage will drop by the time it reaches the battery so in a sense putting the DC-DC at at the supply end seems like defeating it's purpose and you may as well not even install it at all.
That's my thought anyway, I too am still in the LiFePO4 learning stages.
Brian
Old 11-13-2023, 04:25 PM   #7
SallyForth's Avatar
2023 23' International
2023 27' International
Osprey , Florida
I agree. The purpose of a DC to DC charger is adjust the output charge voltage according to a particular battery profile. This assumes a proper gauge charge wire with a short run to the batteries. If your charge wire to the batteries is long and or wire gauge is insufficient, resistant will be high enough to drop the charge voltage, preventing your batteries from being fully charged.
“No matter where you go, there you are.” — B. Banzai
SallyForth is offline   Reply With Quote
Old 11-13-2023, 09:33 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Also need amps, more amps equals more drop on same wire, gauge and length.
Old 11-13-2023, 09:57 PM   #9
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
This kind of question always reminds me of why we use AC to power our homes and not DC. As Tesla and Edison battled things out years ago, the fact that DC power doesn't travel well over long distances became an issue.
Same thing here - the DC-to-DC charger should be as close to the batteries as possible since it doesn't travel well over long distances. The amazing feature of a DC-to-DC charger is that it can take in whatever your tow vehicle throws at it and still deliver the proper voltage to the batteries. But the further you move it away from the batteries the less it's able to do its job. You could upsize the wiring between the DC-to-DC and the batteries to compensate for this, but then you're back to doing the contortionist thing.
Richard
11018
richard5933 is offline   Reply With Quote
Old 11-14-2023, 07:18 AM   #10
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
That's where it gets complicated, the Li will draw heavy amps during bulk charging which will increase voltage drop significantly but as it nears the end of the charge cycle the amps will drop to nothing and the voltage will go high, so it's kind of a moving target and how much voltage is needed at any time during the charge is yet another calculation. The length of time to fully charge is another variable dependent on the combination of available amps and volts.
There are folks who can figure all that out for a given scenario but I'm not one of them.
Brian
Old 11-14-2023, 08:02 AM   #11
2022 19' Bambi
Northeastern , Pennsylvania
This is my understanding as well. And most LFP batteries don't like to stay up over 14V for very long, which is why most chargers have a timer for that cell balancing phase, after which they drop back to a float voltage in the 13.6 range. Your charger will be able to time this more accurately if it knows the actual battery voltage, not the voltage several feet away.
Some of the Victron products have VE.Smart networking to help manage this--they can use the voltage measured at the battery terminals by the shunt, sent to the charger via Bluetooth. But I don't think their DC-DC chargers do this (yet?). They have a new Smart Buck Boost coming out that I'm hoping may get that feature. https://www.airforums.com/forums/f37...er-248200.html.
DarthBrader is offline   Reply With Quote
Old 11-14-2023, 10:08 AM   #12
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Simple answer:
You put in the DC/DC to take care of few things:
1) The wire drop due to the current
2) The somewhat variable output of the TV alternator
3) The voltage needs of your LiFePO4 batteries
Of the three, number 1 is the biggest issue. Unless you run very heavy wire back to the bumper *and* in to the trailer it will still be a problem. Putting in all that wire through all those places is not going to be easy.
Compared to the rest of the "fun" switching to a lithium setup, the DC/DC part was by far the easiest thing I did.
Old 11-14-2023, 10:11 AM   #13
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
So, I have actually done this, partially. '06 Ram 2500 Cummins, '68 Overlander, '92 Hallmark truck camper, truck topper. Put the Victron Orion 18 in the truck bed where it is 3 feet from the truck camper battery (a regular FLA). Ran double 6 AWG from truck battery to charger and then to battery. I've done several good trips and it's worked great. Plan is to be able to extend to the trailer when needed, that hasn't happened yet but is a big reason I went with the 6 AWG. I suppose I could move the Orion to the trailer or just put a second one in the trailer and by-pass the one in the truck. I've taken it in and out a couple times and takes 5 minutes.
Best regards, Mark D
mrdes8 is offline   Reply With Quote
Old 11-14-2023, 10:19 AM   #14
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Thinking about this a bit more, could make a big difference if the batteries are on the tongue or like mine, 15 ft. further back mid-trailer.
Best, MD
Old 11-14-2023, 10:24 AM   #15
Racine , Wisconsin
What about putting an inverter in truck, then running an AC cord to a modern battery charger in trailer?
Dave Bybee
2017 Ram diesel, air suspension
1986 Avion
Kilroy is offline   Reply With Quote
Old 11-14-2023, 11:19 AM   #16
1994 25' Excella
You mentioned that you're not so young and not a contortionist, thus making installing the DC-to-DC in the trailer difficult.
What about hiring someone younger and more able to contort to do the install?
Richard
11018
Old 11-14-2023, 12:17 PM   #17
Carmel , Indiana
Haha yes, it’s only $$$. I will likely find a place on the trailer.
Some additional info. I have a 2021 Globetrotter. 2 100a batteries in the battery box. The thought was to but the DC/DC converter right inside the tailgate mounted on the side. I’m not envisioning to much of difference in cable length (maybe a few feet)
Anyway, I appreciate the feedback. Will likely find a spot on the AS in the storage area up front.
Thank all!
Old 11-14-2023, 04:07 PM   #18
2023 28' International
Mercer County , New Jersey
That would be very inefficient. You'd be paying the energy conversion tax 2X - once from DC to AC and then from AC back to DC
jeffb831 is online now   Reply With Quote
Old 11-14-2023, 04:23 PM   #19
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Location of DC-DC charger
Mr Wonderful, I can share where I put my DC-DC charger in our 27’ GT FBT. I have a Renogy 40A unit and put it under the curb side bed, just above the DC junction box.
I’ve got a Battle Born GC3 inside the street side compartment extending into the front compartment. I did run a pair of 4 AWG cables under the truck to the bumper and used Anderson 150A connectors to the trailer.
I think you’re right about the distance being close to the same if you installed the DC-DC charger in the truck bed vs. inside the trailer. That said, inside the trailer the charger is protected and not that hard to get to.
By the way, the DC-DC charger worked great and allowed us to run the 3-way fridge on 12V instead of propane when on the road. Well worth the effort!
Hope that helps!
-Jeff
ID:	438761   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 11-14-2023, 06:32 PM   #20
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
Love ya Jeff! But I get fixated on that upside down mount. Lol
Life is a Highway is offline   Reply With Quote
Can I use PVC instead of ABS for DWV? AuntieLori Waste Systems, Tanks & Totes 12 08-30-2016 11:12 PM
Can I use another product instead of interior skin? Rayvynus Ribs, Skins & Rivets 20 05-07-2016 10:56 PM
SUV guy curious about Truck with shell instead. Dog, kids, etc.. Danattherock Tow Vehicles 34 07-30-2015 12:02 AM
Can I mount Awning Track instead of Trim Rail? bass-o-matic General Repair Forum 0 01-19-2015 03:20 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 10:39 AM
