RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-11-2019, 12:05 PM   #21
jimro's Avatar
2019 27' Globetrotter
Edmonton , Alberta
Crimping is for sure easier, and as others have noted, a crimp tool for that gauge is not expensive. I've used pre-loaded lugs for larger gauge cable and they seem to work well too; no issues after five years of use.
jimro is offline   Reply With Quote
Old 03-11-2019, 12:14 PM   #22
2007 22' International CCD
Cable lugs - crimp or solder
Biggest thing with using soldered lugs is to support and route the wire in a manner that avoids flexing at the solder joint. Vibration is the enemy of soldered connections because the wire is stiffened and becomes a bit brittle where the solder wicks into the strands.
The parts listed in jimro’s post seem to be quality stuff, and adhesive heat shrink would protect the wire from corrosion and vibration as well.
Personally, I’ll still crimp stuff, as I have the right tooling. Heat shrink gets added either way.
Just be sure to use good parts and techniques, and it should be fine.
Admittedly we’re not building aircraft or spacecraft around here. (But we can dream, right?)
Old 03-12-2019, 07:43 AM   #23
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Now, that really burst my bubble!! (Sorry. I couldn't resist!)
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 03-13-2019, 09:13 PM   #24
1976 31' Excella 500
N. Richland Hills , Texas
Originally Posted by GMFL View Post
Crimp and adhesive heat shrink. I have learned that solder causes the stranded wire to becom stiff at the connection and when the wire bends close to the joint it will eventually break.
Cable assembly manufactures will tell you that soldering cable connectors creates stress points at the point where the solder end, and these stress points are the first place cable assemblies break due to vibration with the assembly.
Regardless of which method you choose to use, note that cable assemblies must be strain relieved close to their connections to dampen down vibrations. The best teaching example is to open the hood of you car and note how manufactures install cable assemblies.
The best of luck to you.
T2Airstream is offline   Reply With Quote
Solder Seal vs. Scotch-Lock ericpeltier Electrical - Systems, Generators, Batteries & Solar 10 02-01-2017 06:26 PM
Battery cable lugs Jrglenn Upholstery, Blinds, Walls & Interior Finishes 3 02-19-2016 06:55 AM
Possible to solder an extension up front for a motorcycle GP1152 Towing, Tow Vehicles & Hitches 20 12-05-2013 12:33 AM
Poly fresh water tank repair-solder iron rogerdodger Fresh Water Systems 7 10-07-2012 04:49 PM
Lead solder ? Will Ackerman Plumbing - Systems & Fixtures 6 06-28-2004 07:16 PM
