Newbie here... I have a ‘95 excella and plugged two heaters in and heard a breaker switch. i’ve lost power to all of my outlets except the one in the back bedroom. the little black button behind the copper bar on my panel seems to be stuck too..
The picture shows your 12volt breaker box. You need to reset your 110volt breakers. They are usually in the bedroom at the back and quite often in the overhead compartment. You cannot plug in 2, 1500 watt heaters on the same circuit. Are you plugged into a 30 amp service? If you are plugged into a 15 or 20 amp service at home, you will pop the house breakers as well.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
