Old 03-08-2021, 11:18 AM   #1
2000 28' Excella
Brooklyn , New York
Question Battery Replacement Question
I had both batteries fail, and had to replace them. The previous batteries were Interstate Marine/RV Deep Cycle SRM-27s
I replaced with Duralast 27DP-DL Group 27 Starting Marine and RV
I assume these are compatible, but I'm not a battery expert at all, and the folks at AutoZone on a Saturday night were not the most knowledgable either.
Would appreciate any confirmation/comments.
Brett
Brettwieland is offline   Reply With Quote
Old 03-08-2021, 01:05 PM   #2
AKNate's Avatar
2018 30' Flying Cloud
Anchorage , Alaska
The 27DP-DL is a starting battery. You want a deep cycle battery. The 27DC is the correct one in the Duralast line. Starting batteries are designed to provide short bursts of high current. They are not designed to provide continuous current over a long period like you want in an RV application. Deeply discharging a starting battery will shorten its life much more than it does a deep cycle.
AKNate is offline   Reply With Quote
Old 03-08-2021, 02:32 PM   #3
B. Cole's Avatar
1977 31' Sovereign
Rochester , WASHINGTON
Agree w/ AK Nate-
AutoZone should exchange those for deep cycles.
Anyone needing batteries, keep in mind,Wal-Mart has big Deep Cycle boat batteries for approx $99 each.
They take a real beating, and if they go bad,( rare )will exchange/ pro rate them at any Wal-Mart across country.
Ive torture tested those at 0 degrees in boats with electric motors duck hunting.Far superior to Interstates, in my opinion.
Airstream rodeo clown, it's my turn in the barrel 🤡
B. Cole is offline   Reply With Quote
Old 03-08-2021, 04:29 PM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
The above is correct,
However I had a cheap car battery in my airstream for about 3 years and it worked just fine, now that battery has been in my stockcar trailer for two years running the winch and it’s worked fine for that but obviously is not ideal.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
AldeanFan is offline   Reply With Quote
Old 03-08-2021, 07:18 PM   #5
2000 28' Excella
Brooklyn , New York
Thank you all for the comments, I appreciate it!
Battery or Not to Battery, That is the Question. JeffofCT Batteries, Univolts, Converters & Inverters 12 08-27-2020 12:57 PM
Battery (or converter) replacement question umasslax Batteries, Univolts, Converters & Inverters 8 05-17-2020 08:07 AM
13.65? Agm Battery charging, plus battery monitoring question Mx468 Electrical - Systems, Generators, Batteries & Solar 1 05-08-2019 09:24 PM
Shore power not charging battery after battery replacement P and Y Batteries, Univolts, Converters & Inverters 15 11-22-2016 08:36 AM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
