We just purchased a brand new 2022 Flying Cloud 30' Bunk. We've taken it on two 1-night "test trips." Everything worked perfectly. Until...
When we returned from our second 1-night trip, we could not turn the Battery Power switch on or off. It was completely dead, as was all
12V power in the Airstream. Even connected to shore power, we can't use
12V (no lights, etc.)
Thinking we had a bad Battery Power switch, we got a new one from the factory. After installing it, the problem is the same. When you press the Battery Power button, no blue light comes on and no "click" indicates that it is functioning at all.
The inverter seems to be working and registers 12.4V.
Using a voltmeter, we tested the wires at the switch and they register 12.4V so it seems the Battery Power switch is getting power.
Checked the breaker panel and all fuses are working and no breakers are tripped. All fuses on the external batteries themselves are in good condition and all cables are secure.
Does anyone have any ideas as to what could be going on? We have a big trip planned in a couple weeks and we literally can't turn on the lights in our brand new trailer.
Thanks for any help you can offer!
