09-18-2018, 08:16 AM
2019 19' Tommy Bahama
MILBRIDGE
, ME
Battery maintenance during storage
I have a 19' 2019 FC with the solar package. As I understand it, with a solar package, you have the AGM batteries installed. I sprung for indoor storage, which is basically a big warehouse with a very few skylights, so I imagine not much charge is received by the panel during storage. The other day, I drove to the storage facility to perform some very minor upkeep, and the battery was so drained that the interior lights would not turn on. I checked the battery percentage, and it was down to about 8.9%. I understand that there are a few devices that require a trickle of electricity even if the battery is switched to the "store" mode (such as the LP gas detector). So my questions: is this normal, and is it bad for the batteries to be run down this much? I seem to remember reading somewhere that the AGM batteries do not need to be trickle charged or maintained in the same manner as traditional lead acid batteries. Is this true? Thanks for your help.
09-18-2018, 08:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 👍
I have always removed our AGM's in the AS. After installing an AGM in our boat and leaving it installed & disconnected for the last 4 yrs with no problems,(still above 12.5v in the Spring), I started doing the same with the AS for the last three yrs...plan to do the same with the new BB Lithiums. 👍
09-18-2018, 08:32 AM
2018 27' Globetrotter
Apollo Beach
Your batteries were probably drained to 8.9 Volts, not 8.9%. In my experience, this level of draw down will permanently damage a battery, but I'm not an AGM battery user. I too murdered my first set of Airstream batteries in a similar way. After about 30 days of non-use, the parasitic loads will begin damaging the batteries. The solution to stop these parasitic loads is to disconnect the negative battery cables when you will not be using your Airstream for more than 30 days.
I installed a battery disconnect post so I can flip one lever to disconnect the batteries. Here is what I installed: https://www.amazon.com/WirthCo-20148...PT3GRJVEZ183S8
This is a picture of it installed: http://www.airforums.com/forums/f42/...ml#post2079369
Flipping this lever each time you store your Airstream will solve your battery issues.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
09-18-2018, 08:40 AM
ObviouslyKnot
KAILUA
, HI
I ran my Classic AGMs down within a week of delivery such that the LEDS flickered. Two years later, still chugging, boondocked this month just fine. I did install twist knob disconnects so can easily remove inverter load and open both for trickle charge maintenance.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
09-18-2018, 08:41 AM
ObviouslyKnot
KAILUA
, HI
Chugging at x% of original capacity, who knows?
09-18-2018, 09:19 AM
2019 - 33' Classic
2019 33' Classic
Grand Junction
As a newbie there are so many things you can avoid by being part of this forum. Thank you to all of you for your expertise and experience. There are also many things you have to find out the hard way. I am in the process of finding out the hard way with my wet batteries that I need to replace after sitting up to 3 weeks at a time in storage. I would've loved to see the battery shutoff as standard. I am going to Amazon now to order it now. Thanks!
Rick & Michelle Nelson
Grand Junction, CO
2019 Classic 33
09-18-2018, 09:23 AM
2014 30' International
DFW Airport
I agree with the disconnect approach completely. My experience managing 14 batteries of AGM and Wet format, is that using a smart charger while leaving the battery connected does nothing to enhance the life of the battery. The parasite draw and recharge process may be the cause. One battery that I only use occasionally and is otherwise disconnected has now past 7 years and is showing good performance.
09-18-2018, 09:04 PM
New Borockton
, Alabama
I certainly respect but completely disagree with that. I've floated and maintained flooded and AGM batteries for over 10 years on three different campers with success. Airstream, Lance and Tiffin products with Lifeline and other batteries. You do have to manage the parasitic loads or eliminate it but it's easy to manage if you know where it exists but the dusufation cycle does work. There are many members here that have used 4 stage converters for years and still on their original batteries. Some are on their second set of batteries before learning the benefits of multi-stage charging and maintenance. I installed my Lifelines in 2007 and they still work (admittedly getting week.) I keep saying that but my daughter just got married so I keep putting it of
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
09-19-2018, 02:13 AM
Sag Harbor
, New York
Accurate advice will depend on a host of factors, such as your distance from the indoor storage area, your willingness to go there, and so forth. Do you have one or two batteries? Your frequency of use is another important factor. With fall and winter approaching, how often do you intend to hook up and tow?
To get through the next 6 months or so, the difference between AGM and flooded cell batteries is not all that relevant IMO. You are not able to keep the batteries charged at all, so you probably need to pull the batteries and trickle charge them in a convenient location. The most you could expect the batteries to last is 2 weeks, without charging, IMO.
Again, this depends on your lifestyle, intended use, etc. etc., so please fill in the blanks for better advice.
Happy trails!
Peter
PS -- Great resource for general info: http://www.batteriesnorthwest.com/ba...hool.cfm?TID=0
PS2 -- This thread in the Batteries etc. sub-forum would also be good to check out: http://www.airforums.com/forums/f449...ge-185428.html
09-19-2018, 11:41 AM
DFW Airport
I am reflecting my experience. Replaced 5 batteries this year, none of which were ever allowed to sit more than a day without being on a 4 stage charger. And where then known parasitic loads like inverters were present, they did not sit more than 15 minutes.
My guess and that's all it is that battery life is no longer more than 4 years because of poor material ( including Lifeline) or only certain chargers are really up to the job they advertise. I am prepared to accuse Battery Tenders of being seriously deficient to their claims as an example.
09-19-2018, 12:25 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Originally Posted by ROBERT CROSS
I have always removed our AGM's in the AS. After installing an AGM in our boat and leaving it installed & disconnected for the last 4 yrs with no problems,(still above 12.5v in the Spring), I started doing the same with the AS for the last three yrs...plan to do the same with the new BB Lithiums. [emoji106]
[emoji631]
Bob, may give you piece of mind that I happened to reach out to Battle Born the other day on this very issue as I will be storing my trailer soon. They said to expect no more than 3% self discharge per month so I will be unhooking them completely and storing them with my trailer for 5 months.
@living.somewhere.yonder | Instagram
09-19-2018, 12:44 PM
Apollo Beach
I agree with Randy that floating the battery with the "correct" charger is a good option if you have a power source. I use my suggested battery disconnect switch when I cannot float my battery with my converter or solar. I replaced my converter with a PD4655, from Randy, but predominantly use my Victron 100/30 and solar to maintain my batteries. I leave my solar on in storage because I have adequate sunlight.
Here are some items that can murder batteries:
Chronic “PSOC” Use – Partial State of Charge Operation
Temperature Abuse- Heat MURDERS BATTERIES.
Poor Charging Practices
Absorption voltages set too low
Inadequate absorption voltage duration (under absorbing or premature floaulation)
Incomplete or Under Charging
Over Charging – Old school non-smart chargers
Improper Charging – Poorly designed battery chargers, there are MANY.
No Temp Compensated Charging – If a battery charges at 14.4V this is max at 77F, not at 90F or 100F plus
Lack Of Maintenance – Exposed plates sulfate in short order
Contamination – Happens when batteries are not properly serviced and external contaminates get in
Improper Flooded Battery Orientation
Improper Bank Wiring – Poor wiring practices can cause interbank imbalances
Lack of Proper Equalization Charges –
Batteries Sitting at Less Than 100% SOC – Especially for for days or weeks
09-19-2018, 01:34 PM
Sag Harbor
, New York
Wondering if you could fill in more details, per Post #9?
Peter
09-20-2018, 07:14 AM
MILBRIDGE
, ME
The drive to my storage facility is about 20 minutes or so. I am retired, so getting there regularly would not be a problem. I have two AGM batteries in the trailer, and the facility does offer to put batteries on a trickle charge if you ask for that service. With winter coming (I live in MD), I do not expect to be using the trailer much after November until the spring. I suppose I could disconnect the wires connected to the negative poles on both batteries to prevent the parasitic drain, but of course I would have to do this every time I store the trailer. Or I could install a disconnect switch.
Again, I seem to remember reading somewhere that AGM batteries do not need to be kept on a trickle charge to prevent damage or shortening the life of the batteries, but apparently that's not the case.
09-20-2018, 07:19 AM
ObviouslyKnot
KAILUA
, HI
My AGMs lasted months, disconnected, fully charged first. Twist disconnects make it easy peasy. Especially if boondocking, to disconnect the inverter cable.
09-20-2018, 08:23 AM
bhooves
2013 27' Flying Cloud
Livingston
Store rig hooked up to power
I called the guy who installed our solar, Starlite Solar, in Yuma AZ. He said to store your rig where you can hook the power up. I have done so for 1 1/2 months and the batteries are at 100%.
Also, Larry's crew at Starlite Solar custom installed 470 watt system on our rig and the only evidence that is visible inside the Airstream is the solar and battery monitor on the wall. Excellent. Starlite Solar, Yuma AZ 928-342-9103.
We're a satisfied solar user, sold both Honda generators. Don't need their noise.
Bhooves
09-25-2018, 07:11 AM
2015 28' Flying Cloud
Durango
A good list. Add depth of discharge and number of discharge/charge cycles and Batteries 101 will be comprehensive.
To go beyond the 'rules of thumb' and anecdotes, I strongly recommend accessing the Lifeline Technical Manual. http://lifelinebatteries.com/wp-cont...cal-Manual.pdf
Safe Travels,
Joe & Joan Donnaway
Durango, CO
09-25-2018, 08:21 AM
Durango
One more anecdote.
I lost a very large bank of AGM batteries on our sailing yacht while in storage on the hard due to someone unplugging the extension cord to my battery maintainers. Lesson learned. Now my boat solar installation ensures battery charging. Likewise, if storing our Airstream in commercial covered storage, I would not trust their power connection. I remove the batteries and bring them to my garage for storage maintenance.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
09-26-2018, 10:18 AM
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah
, NSW Australia
That is still generally true for most AGMs PROVIDED you can start with the batteries 100% charged, or close to it, AND there is absolutely no load on the batteries. 6 to 8 months should be no problem at all.
Need to physically disconnect to be sure of no load.
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
09-26-2018, 10:53 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
As batteries age, they degrade in a lot of ways. What works for a brand new set of batteries may not be perfect for a set that have had many hundreds of discharge cycles or years of use. If you are trying to get the last few years out of your 12 year old batteries, they probably need all the help they can get ....
