Old 10-01-2022, 12:38 PM   #1
Good Times!
great2beadaw's Avatar
2016 23' Flying Cloud
Jasper , Georgia
Battery lost power
We were hooking up the solar panel to the battleborn lithium batteries today on our Airstream. The black alligator clip touched the red terminal and sparked three times. The battery stopped working after the spark. This has happened before and normally the converter resets after we plug it into the tow vehicle. However today the battery did not reset. I checked the breakers and none of them tripped. Any ideas on what else to troubleshoot?
great2beadaw is offline   Reply With Quote
Old 10-01-2022, 01:04 PM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
The Battleborn BMS protects against shorts. Here is the piece of the manual which talks about it. Seems like you have to disconnect the battery cables to reset.
"Short Current Discharge Surges
Our BMS has built-in short circuit protection. If the short circuit protection is tripped, the BMS will shut the battery down and will remain disconnected until you remove the battery cables. While the battery cables are disconnected, we suggest taking the voltage of the battery with a voltmeter. If it reads above 10V, reconnect the battery cables. If you are unsuccessful at obtaining a voltage reading above 10V, please give our technical support team a call."
Richard
11018
richard5933 is offline   Reply With Quote
Old 10-02-2022, 10:40 AM   #3
Good Times!
Jasper , Georgia
Disconnecting the negative cable and reconnecting it worked. The battery reset and is operating again. Appreciate the help!
Old 10-02-2022, 03:00 PM   #4
1994 25' Excella
Good news. Thanks for the followup.
Richard
11018
Lost power to the keyless entry system 92landyacht Land Yacht/Legacy Motorhomes 9 02-06-2013 05:59 PM
Removed control panel and lost all power? deerhunter Electrical - Systems, Generators, Batteries & Solar 1 05-13-2012 10:40 PM
Lost all 12V power Flynavy Electrical - Systems, Generators, Batteries & Solar 22 06-29-2011 05:49 AM
Lost partial power- please help. argo76 Argosy Motorhomes 5 11-17-2009 02:05 PM
Lost partial starboard side power Thealt Lights - Interior & Exterior 15 03-21-2009 08:55 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
