09-13-2022, 07:30 AM
Bloomington
Battery life while in short term storage? 2023 Flying Cloud 23FBT
Seem right?
When in covered storage, no power source, no sun, green master switch by door is off, fuse to jack pulled (to hinder jack use):
Day one: Fully charged 12.9/13.0 volt battery
Day two: 12.4 volt on inverter monitor.
Seems like a lot of battery drain for 24 hours. Right?
I only know of inverters draw on the battery while in store mode, are there others? Mitigation steps to follow?
Thank you for your ideas or experiences!
09-13-2022, 08:06 AM
2017 28' International
Jim Falls
, Wisconsin
You have parasitic draw on the batteries; particularly the LP detector. Recommend putting on a battery disconnect switch. I assume you have AGMs. That should take care of your problem. But I would also recommend charging your batteries at least every month even with the disconnect switch. Do you have a generator? For longer term storage without electricity most take the batteries out and store them at home and either put them on a trickle charger or charge them once a month.
09-13-2022, 09:43 AM
Bloomington
Forgot about the detector draw.
Sounds like the battery disconnect switch will solve my issue. Yes, two AGM batteries on board. Would it mount to one of the Negitive posts on one of the batteries?
Any other parasites eating my batteries on the green button kill?
09-13-2022, 10:06 AM
2002 30' Classic S/O
Fleming Island
It would be best (but probably overkill) to put a disconnect switch on each battery to prevent a weaker battery from discharging a stronger one. As an alternative, connect the two negative terminals together, put a disconnect switch on one, and move ALL negative wires to the other side of the disconnect switch.
On second thought (or maybe third) you may not be able to find a disconnect switch that will connect to the negative terminal while leaving the two batteries connected. If not, the two switch option comes into play.
09-13-2022, 10:11 AM
2020 25' Globetrotter
Hillsdale
, New York
You need a disconnect on each negative post ie both batteries.
SPP
09-13-2022, 10:13 AM
Fleming Island
Seem right?
Is inverter turned off? If not is has substantially more draw than the propane detector.
09-13-2022, 10:20 AM
Bloomington
Yes, I have not been turning it off separately when in the store mode. I’ll need look where I can disable the inverter when in covered storage, unless others know here.
Another good option idea!
09-13-2022, 10:26 AM
Evergreen
If you have any aftermarket accessories in your Airstream, then they may also cause a parasitic battery draw. For example, my weBoost cellular booster is hardwired and it remains powered, even when the main switch is set to “store”.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
09-13-2022, 10:53 AM
2023 23' International
Calgary
, Alberta
Battery Interruter Switch
Attached is a good article about the use and installation of an interrupter switch. It also explains why the switch should be on the negative cable side (many instruction videos suggest the positive). If you have a lithium battery you may also want to install a smart shunt at the same time. It also goes on the negative side.
https://www.mortonsonthemove.com/rv-...onnect-switch/
09-13-2022, 11:25 AM
2007 16' International CCD
Somewhere
Yes, probably. Radio presets, TV antenna, and subwoofer are all suspect. Battery kill switch is the way to go.
If you want to identify and understand your trailers electrical use, you should install a shunt based battery monitor, like a Victron 712.
09-13-2022, 11:38 AM
2019 27' International
2014 25' International
Boulder City
, Nevada
[QUOTE=BHage;2629743]Seem right?
If this is at Home or possibly a secure Storage Area:
Purchase a $99.00 Costco 100 watt Solar Panel with Controller. Run the wiring outside your home or if it can be secured to the roof of the Storage Area.
Two wires + / - to the Batteries.
Otherwise... remove the batteries, take them home and have them connected to a battery charger.
Human Bean
09-13-2022, 11:43 AM
2004 30' Classic Slideout
Fenton
, Missouri
I did some testing on my '04 Classic and with master disconnect on and all appliances in the off setting, the draw was .1 of an amp. When the disconnect is set to off the draw was .01 of an amp (which I assume is the propane detector). Once you know the amp hour rating of your battery(ies), it's pretty each to know how long your trailer will last when in storage.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
09-14-2022, 09:55 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Depending on the inverter you have, it may well pull as much as 1/4 A even when turned off. There are lots of weird things here and there that pull current. As noted above, the only real answer is a full battery disconnect that switches the batteries fully out of the circuit. It can be in the negative or positive lead. It *must* deal with all the wires to the negative or positive post(s).
09-19-2022, 09:01 AM
2020 16' Bambi
Sunset Beach
, North Carolina
Battery disconnect switch solved my problem. Simple ,a few dollars fix. Two AGM batteries 22’ Bambi. Also watch out that your stereo is not powered on. My seems to power on every time I turn on/off the battery switch.
09-19-2022, 10:25 AM
Tampa
If your "short term storage" is a one time deal, you can simply remove the negative terminals and tape or cover them so they can't short. The negs are less likely to short because touching the metal won't do anything.
If storage will be a regular thing, then a dedicated battery disconnect is in order.
I went all in, while some folks use a switch at the terminals.
https://www.airforums.com/forums/blo...sconnect-3036/
