Old 08-01-2021, 06:53 AM   #1
2021 19' Bambi
Westlake , OH
battery/electrical/solar upgrade
Wanted to share;
Ordered Bambi 19cb back in October, picked it up in mid June.
Had solar prewire only and Interstate LA batteries.
Upgrade - (parts: 2 SOK LiFePo4 batteries, bigger cables, Victron Lynx Distributor with bluetooth monitor, Krieger 2000 W inverter, 40 amp Renogy solar charge controller with bluetooth monitor, 3 Renogy 100 W compact solar panels with curved Z brackets.
I wanted option for boondocking to use solar panels to charge my batteries and be able to run microwave and 120 AC outlets all off inverter.
1) replaced LA batteries with SOK LiFePo4
2) disconnected inadequate factory 8 AWG battery cables and pulled through floor to connect to Victron Lynx Distributor.
3) attached 1/0 AWG cables from battery to Lynx distributor. attached 1/0 AWG cables from distributor to inverter.
4) fished wire for solar controller monitor, battery shunt monitor and inverter remote to closet and installed fixed monitors.
5) attached solar panels using AM Solar no drill solare technique with 3M VHB double sided adhesive, covered bracket foot with Eternabond adhesive tape and covered everything with Dicor RV roof sealant.
6) wired solar panels in series and used standard SAE connector in reverse to plug into prewired solar combiner box on roof.
7) attached power cables to solar controller and attached prewired solar (green and yellow) to solar controller
8) looked up which AC circuits were going to microwave and outlets. Placed 2 DPDT switches so I can switch between shore power and inverter power.
Everything works as it should, can run everything except for air conditioner.
sandman227 is offline   Reply With Quote
Old 08-01-2021, 07:16 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Nicely done!
wulfraat is offline   Reply With Quote
Interstate Battery & Solar Panel Upgrade PirateChris Sprinter and B-van Forum 100 02-06-2021 10:31 AM
Original 2015 55 AMP Converter (battery charger). Removed for complete solar and electrical upgrade. Works perfectly. Gulliver72 Airstream Classifieds 0 06-15-2019 10:22 AM
Advice about battery/solar upgrade gmillerok1 Sprinter and B-van Forum 52 07-07-2018 10:50 AM
Solar and Battery Upgrade for 2015 Interstate tlundell Sprinter and B-van Forum 42 04-17-2018 12:35 AM
Converter,battery and solar upgrade SilverSinbad Batteries, Univolts, Converters & Inverters 2 01-19-2015 10:57 AM
