RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-05-2019, 10:16 PM   #21
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Originally Posted by djbar View Post
Battery disconnect switch is on my to-do list. Will prob use BlueSea switch on batt box. Wondering about pro’s and con’s of 2-way vs 4-way switch. Thoughts?
If by 4 way you mean a double pole single throw switch like was mentioned earlier, it has no advantage with batteries in series, like two six volts. If you have mismatched batteries in parallel it would stop the better battery from leaking charge into the weaker one. In practice most people replace both batteries at the same time so, in my experience, a double pole switch isn’t necessary.
daleyocum is offline   Reply With Quote
Old 10-17-2020, 03:27 PM   #22
GSG
2019 25' Flying Cloud
El Rito , New Mexico
nice install
Originally Posted by wulfraat View Post
Here is some more info... 2-way or 4-way blue sea switch. Mount inside or outside of the battery box.
Wulfraat,
I'm taking advantage of your switch install. I do have one question. I have a 2019 FC 25 RB with ACM batteries. I can easily duplicate you install (parts, cable, etc).
My positive cable, that now feeds the inverter, has a 100 amp buss fuse on it. May I simply run my 1/0 positive cable to feed the Blue Sea switch from this fuse, then have the inverter on one side of the switch and the converter on the other?
GSG
garysgriffin is offline   Reply With Quote
Old 10-17-2020, 05:01 PM   #23
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Battery Disconnect Switch--Where and How Install
GSG
Yup. Just know that all loads (house+inverter) should be less than 100A if you do this (I think I am following - IE place 100A fuse between all loads and batteries)
wulfraat is online now   Reply With Quote
Install Battery Disconnect Switch dasams Batteries, Univolts, Converters & Inverters 39 03-31-2020 09:23 AM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 32 08-26-2019 02:23 PM
23fd Battery disconnect switch install pfcardwell 2016 - Current Flying Cloud 218 05-18-2019 09:33 AM
Disconnecting Negative = Install Battery Disconnect? 2Highplains Electrical - Systems, Generators, Batteries & Solar 2 03-18-2019 09:21 AM
Battery Disconnect Switch and Relay wcrockett Electrical - Systems, Generators, Batteries & Solar 2 09-11-2015 01:57 PM
