09-19-2017, 09:02 PM
2016 30' Classic
Naperville
Battery disconnect switch light
On my Intellitec Battery Disconnect panel the red light is on all the time when I am connected to 110 house power, both when I am in STORE or USE mode. Is that right?
Ed
2016 Classic (with ProPride)
2016 Silverado 3500HD Diesel drw
1995 & 2004 Gary Fisher Hoo-Koo-e-Koo emergency vehicles
09-19-2017, 10:18 PM
2016 27' Flying Cloud
Manteca
Yes, that's correct. You can't turn it off when you're on shore power.
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
09-20-2017, 05:33 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
A caveat - if you put your Use/Store switch in Store Mode and have a power failure your refrigerator won't switch and run on propane (if on automatic setting) as it needs 12v power.
Ray B.
01-23-2018, 11:36 AM
2015 30' Flying Cloud
Travelers Rest
, South Carolina
SO the fact that it is always on when on shore power ... what is impact on batteries?
01-23-2018, 11:41 AM
Manteca
We installed an upgraded smart 4 stage charger. If you done have a smart charger you will over charge the batteries and smoke them! Bad seen and they will smell like rotten eggs.
01-23-2018, 12:11 PM
2007 22' International CCD
Corona
Perfectly normal.
The stupid light DOES NOT tell you the state of the battery switch.
It's wired to simply tell you that you have 12 volt power available for your 12 volt appliances. It has NO idea if your batteries or convertor are providing the power.
After a lot of analysis and research, I found out that there is no other way to make it work, because the relay that the use/store switch actually controls is a mechanically latching relay that provides NO indication of its position. You have to hit the switch to the appropriate selection and listen for the 'clunk' noise to verify something happened....
I'm replacing that POS with a real Blue Sea latching battery contactor and associated switch/indicator that tells me if it is activated or not...
01-23-2018, 01:24 PM
Tampa
As I understand it, the light lights when shore power is detected.
It doesn't matter if it's in "use" or "store".
01-23-2018, 02:00 PM
Corona
Just 12 volt power present...doesn't care if its battery or convertor supplying it.
03-28-2020, 04:15 AM
2017 27' International
Orland Park
Switch light not lit on shore power
What does it indicate if the light is no longer on when on shore power?
The 110v outlets are live but the lights and refrigerator only work when switch is in the use mode.
Mark
03-28-2020, 12:48 PM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
Lights & reefer are 12v not SP.
03-28-2020, 02:15 PM
Orland Park
Bob Thanks,
I get the 12v part. The odd part is for the last 3 years and 22,000 miles the red light was on (and the lights and fridge worked) regardless of the switch setting when connected to shore power.
Today the light is out. So either it was misbehaving from purchase until now or it is starting to misbehave now.
Mark
03-29-2020, 12:23 AM
Corona
Sounds suspiciously like the convertor may be having an issue or the LED is fried. Time for the multimeter!
04-05-2020, 06:15 PM
Orland Park
It was the converter just replaced it with a Boondocker 1260 HWL.
Mark
04-05-2020, 07:18 PM
Corona
Thanks for the update! That closes the loop on the problem/solution...for future readers.
Good choice of a replacement as well.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Battery Disconnect Switch Not Working
Toronto_Guy |
10 |
06-26-2020 02:35 PM |
Battery Disconnect Switch, Solar & AGMs
SilverGate |
32 |
08-26-2019 01:23 PM |
Battery Disconnect Switch Question
MaryD |
4 |
07-13-2013 08:19 AM |
nsbcpa |
5 |
08-10-2012 05:11 PM |
Electric perplexity: Opinions solicited, pump,disconnect switch, fluor light sympto
hshovic |
2 |
11-19-2008 08:25 AM |
