02-21-2021, 11:44 AM
2021 27' Flying Cloud
Modesto
Batteries not charging on shore power
2021 27ft Flying Cloud with Solar. Batteries will charge from solar or from TV but do not charge while on shore power. Thoughts ?
02-21-2021, 12:09 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard👍
First...
Converter breaker tripped?
02-22-2021, 07:23 AM
Modesto
Checked the breaker, it is not tripped......
02-22-2021, 07:37 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Does the converter have a fuse?
Should have at least one 30a.
02-22-2021, 07:39 AM
2002 25' Safari
Dewey
Check the voltage on the output of the converter. It should increase to 13+ when the trailer is plugged into shore power. If it does change, the converter is not working. My Processive Dynamics converter has a fused output, not sure what you have.
A new converter might be in your future. Not a bad thing as there are much better replacements than the original.
Richard
02-22-2021, 11:56 AM
2021 27' Globetrotter
Daytona Beach
Definitely a converter problem. I just changed one on my toy hauler, there are fuses on the back of the unit, but mine was tripping the breaker. The big problem was locating the thing. They will hide them wherever there is room. Mine was in the basement under the stairs to the bedroom. Also, everyone will tell you to help locate it just listen for the fan running.......well, if it's tripping the breaker no fan will be running. I always carry an assortment of tools, a battery charger being one. It's a good thing to have with you, if your converter goes out you can use the charger until you get the converter replaced. After all, thats all it is, is a fancy battery charger.
02-22-2021, 08:48 PM
Modesto
Thanks for all the input....now to go look for the fuse......
02-23-2021, 03:41 PM
Airstream Ambassador
Jackson Center
, Ohio
Hi ctg,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Batteries not charging via shore power???
crazylev |
Electrical - Systems, Generators, Batteries & Solar |
32 |
09-07-2023 03:01 PM |
Batteries not charging from shore power
Bash |
25 |
07-26-2021 07:22 AM |
philly_air |
Batteries, Univolts, Converters & Inverters |
12 |
12-01-2019 08:37 AM |
Batteries not charging on 30 amp shore power
Presitla99 |
22 |
10-06-2019 08:11 AM |
Batteries charging from solar but not shore power
johndorst |
3 |
11-16-2016 03:18 PM |
