Old 09-24-2020, 03:59 PM   #1
2016 28' Pendleton
Bettendorf , Iowa
Batteries not charging...
Batteries are not charging on shore power. They are charging when connected to my tow vehicle! Help, please.
DavidIowa is offline   Reply With Quote
Old 09-24-2020, 06:16 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Do you have trailer in USE mode? In most newer trailer they will not charge in STORE. If you are in USE mode, either you have a bad fuse or circuit breaker or your converter has come unplugged or is bad.
Old 09-24-2020, 07:23 PM   #3
2017 28' International
Baileys Harbor , Wisconsin
I have 2017. To charge batteries switch must be “in use.” If they don’t charge then something else is a problem. P.S. Might be good to carry a battery charger with you. You can get them cheap and plug it in to the outside of Airstream.
Daquenzer is offline   Reply With Quote
Old 09-24-2020, 08:30 PM   #4
2018 25' International
Slidell , Louisiana
the Converter also has a dedicated breaker so check that. The Converter manufacturer will have a troubleshooting guide to walk you through testing it as well. since you are getting use out of the battery, I assume the 12V thermal breakers and or fuses are good.
Brian
BayouBiker is online now   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 08:12 PM
Coach batteries not charging jdgreen227 Batteries, Univolts, Converters & Inverters 0 08-10-2009 04:00 AM
Batteries Not Charging With Generator timkim Batteries, Univolts, Converters & Inverters 5 08-09-2009 06:30 PM
Batteries not charging while driving wildwoodrver Electrical - Systems, Generators, Batteries & Solar 36 08-22-2008 05:33 PM
Motor Home batteries not charging myfirstrv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 17 06-20-2008 10:58 AM
