Originally Posted by GOUSC
I have a 2018 Globetrotter with factory solar. When connected to Honda 2000 generator or 20 Amp service at home my batteries show 100% and above 13 volts on the solar display panel in the coach. Also, the solar does not show any charging when connected as such.
When I am connected to 50 Amp service the same display shows 55-60% battery level and 12.4-12.5 volts. Also, during daylight the display there is some solar charging done at various times. The batteries never rise above 60% charge.
Any suggestions as this does not seem normal to me. Any settings that need to be changed anywhere?
Is the converter getting power? Check the breaker.
Also check the voltage at the batteries. Assuming since you have factory solar that you have the AGMs. What is their voltage?
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
