08-15-2016, 04:15 PM
From Beautiful Egg Harbor
2016 25' Flying Cloud
Egg Harbor
, Wisconsin
BARALDI RANGE HOOD--Shuts Down During Use
2016 FC-25 The range hood shuts down when in use with oven and one burner going. After we're done cooking it functions again. There is obviously a thermal breaker someplace in the hood. I would like to know if others experienced this and how you went about remedying the matter. When operating, the hood seems fine.
I called AS Customer Service and the fellow I spoke with took info and called back later. He told me that the FC-25 was designed for "Camping Cooking!" Apparently the intent is that one should not utilize the range/oven and should cook outside! Otherwise, we love our new trailer and are looking forward to two months of exploring out west in Oregon and California this fall. We also love pot roasts!
08-15-2016, 06:34 PM
2012 27' Flying Cloud
W
, New England
That's such odd advice! Not acceptable!
I would have said your 3A fuse needs to be replaced by a 5A fuse (which I've done in mine) but the fact that it works again later has me stumped. You should be able to use it however the heck you want! Camping cooking? What the heck is that? If you're cooking on your stove in the camper, the hood should work!
Sheesh...
Wish I could be of more help.
08-15-2016, 06:59 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
Camping cooking, hooey.
When mine did this, I found that the electrical connection,up behind where the fuse is located, was loose and may have been shorting out against the aluminum side wall. I messed with it a bit, put some electrician's tape on it, replaced the fuse with a 5 amp one and it has not malfunctioned in 4 years. Good luck. Jim
08-16-2016, 08:51 AM
2020 Classic 33
Box Elder
, South Dakota
And not to add to the noise on Baraldi make sure you 'slide' the switches. If you push in on them very hard the switch assembly will push into the hood, just plastic prongs holding it to the front plastic faceplate. Not hard to fix but if the prongs break then it is a $100+ part.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
08-16-2016, 09:36 AM
Ready-to-Travel
Walkerton
Be sure that the outside flap is not latched down in the travel position.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
08-16-2016, 01:22 PM
2015 30' Classic
Sherwood
Ours worked sometimes and the next time it wouldn't. Turned out the fuse holder cap was not tight.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
08-16-2016, 06:33 PM
1997 25' Safari
Burlington
And sometimes the little fuse is too short and you have to put a wee bit of tinfoil on one end. Jim
08-16-2016, 08:43 PM
2017 23' International
Curry County
Could someone give me the specs on the fuse that go in the vent? Unfortunately the existing fuse blew a good while back and I took it out to get a replacement and of course lost it. In the meantime I have tried several attempts to purchase a 5amp fuse that I thought would fit only to find out when I tried to fit it in -- it was too long. If you could also tell me where you purchased your replacement fuses that would likewise be appreciated.
05-29-2017, 03:02 PM
2012 25' FB Eddie Bauer
Virginia Beach
Amazon.com. search for 5 amp slow blow fuse.... you want size 5mm x 20 mm, and you'll probably have to buy a 10 pack.
I looked high and low trying to find one locally with no luck (Radio Shack is gone) but reading an Amazon review taught me that electric guitars and amps use these fuses quite commonly.
Happy hunting, Paula
