Originally Posted by Mainiacs
Hello everyone,
We’re trying to find the location of a fuse that is located in the rear of the van and works with the shore power connection. Is anyone familiar with this?
Our van was stored outside in the cold for several weeks, and now we have no power, so we’re exploring all the possibilities.
Anne
Hey Anne. Long time no post. How did you resolve your inverter problem?
We both own the exact same models of Avenue Suites, but as far as a "fuse" for the shore connection, I'm not sure what you mean. I only know of breakers for 120v power. I assume you've flipped them all fully off, then back on, since they can sometimes look good when they're actually tripped.
Are you positive your 30A coach outlet and cord connections are not damaged or melted (ask me how I know) and you are getting good current to your cord?
More information would help, however, everything you'd need to look at is under the curbside rear ottoman.
EDIT: Be very careful as you will be exposing live connections. Make sure the 30A power cord is unplugged, inverter off, and battery disconnect switch is off when working in there.
