Old 01-18-2021, 05:08 PM   #1
2008 23' International
santa maria , California
Atwood lp gas detector/now no power
Hi all, now retired and trying to get everything ready for a life again. Our old atwood detector kept chirping and realized it was beyond time. Ordered the new smaller one and ready to put in. Not coming on. Checked the wires hooked to the old one with a meter and no power. Checked fuses and no problem there???
Any help would be appreciated
don
don4795 is offline   Reply With Quote
Old 01-18-2021, 06:33 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
What fuses did you check? My trailer is different than yours (2013 25FB) and the power for the detector does not go through the main fuse box. In mine, the detector wire is directly attached to the input side of the use/store relay, hidden in the front right corner under the bed. The fuse is a glass in-line type, near that end of the wire.
SSquared is offline   Reply With Quote
Old 01-19-2021, 05:29 PM   #3
thank you
Thank you so much for your help. I had forgotten that a direct battery hookup would have a fuse to the front of the trailer. Tore it apart and was able to get 1amp fuse at home depot(5 pack for $1.98).
Thank you again. all is working
Don
Atwood RV Propane Detector robertwarren General Repair Forum 6 10-29-2018 02:06 PM
Atwood Detector no power Mame General Repair Forum 0 12-29-2012 06:35 PM
No power to LP gas detector JimmyT Electrical - Systems, Generators, Batteries & Solar 5 10-07-2010 07:48 PM
What fitting for GAS on Atwood gas/elec WH rlindberg Water Heaters, Filters & Pumps 1 04-10-2010 12:29 AM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 04:59 PM
