RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-23-2020, 08:41 PM   #1
Attaching Upgraded Cable to Negative Bus Bar
I am relocating my batteries and have upgraded my battery cables with a heavier gauge, terminated set from Spartan Power. What is the standard method of attaching terminated cables to the negative bus bar?
I believe the larger set screws of the bus bar are 5/16"-24. In theory, I could use a small length of 5/16"-24 threaded rod inserted into the bus bar, followed by a nut to lock it in place (as well as to provide a spacer to prevent the terminated end of the battery from resting on adjacent set screws), followed by the terminal, then the terminal nut, as diagrammed in the attached image.
While I feel this would work quite well, I didn't want to overlook any tried and true methods!
Thanks everyone.
2006 25’ Safari SE FB, aka “WALL-E”
2014 ML350 Bluetec 4Matic
Reese WD Hitch w/ Lippert Straptek “chains” on Can-Am RV custom short stinger, 145W solar, PD 4655 converter, Duracell Group 27 Ultra Platinum AGMs
WALL-E is offline   Reply With Quote
Cut-Off Switch for House Battery: Install on the Negative Cable or Positive Cable? Searching Batteries, Univolts, Converters & Inverters 27 04-18-2020 07:08 PM
DC Bus Bar Box - Question - Loose bar free in box JennyJakeNH Electrical - Systems, Generators, Batteries & Solar 1 07-16-2019 06:37 PM
2005 Airstream Skydeck - Hospitality/Party Bus - NASCAR Tour Bus eBay Watch Airstreams on eBay 0 01-20-2012 11:00 AM
2005 Airstream Skydeck - Hospitality/Party Bus - NASCAR Tour Bus eBay Watch Airstreams on eBay 0 01-13-2012 11:00 AM
2005 Airstream Skydeck - Hospitality/Party Bus - NASCAR Tour Bus eBay Watch Airstreams on eBay 0 01-06-2012 09:00 AM
