Old 08-24-2016, 11:15 AM   #1
dkrukosky's Avatar
1975 27' Overlander
Landenberg , Pennsylvania
Armstrong AC loud at start up.
My Armstrong TR25-14 AC unite has started making a terrible racket when it first starts up and only lasts for about the first 15-20 seconds then quiets back down. I know its not the squirrel cage fan as it runs consistently. I am thinking the compressor is going? Any thoughts?
dkrukosky is offline   Reply With Quote
Old 08-24-2016, 11:28 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have the original Armstrong AC on my 68. It is loud for 10-12 seconds as the compressor comes on then just hums. It also makes a clunk when it shuts off. Been making the same sounds since I've had it for 7 years and lots of hours run tme.
Check the voltage at campgrounds, low voltage can cause issues at startup. Don't run the AC with your trailer just plugged into an extension chord and 15 amp circuit. The starting capacitor could be weak but they tend to either work or not. You need a meter that has the capacitor funtion to get see if it is up to specs.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is offline   Reply With Quote
Old 08-24-2016, 12:33 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'd replace the start capacitor to see if that helps any. It probably won't, but they''re less that $30, so it's a good place to start.
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
drboyd is offline   Reply With Quote
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Armstrong A/C Start Up Watts Swanny Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-16-2012 07:21 PM
Start capacitor for Armstrong 14 A/C pdwhitt Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-04-2011 03:01 PM
High idle, or maybe stuck throttle and hugely loud revving noise at start. PuffinPotter Classic Motorhomes 33 08-08-2011 11:47 AM
Loud range hood fan lbrodsky 2000 - 2004 Safari 5 09-26-2003 06:08 AM
