Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-11-2020, 05:33 AM   #1
1993 34' Excella
Barry's Bay , ON
Are 12v breakers really self-resetting?
I plugged a 300w inverter into one of our round 12v outlets thinking “I’ll never use the full 300watts (generating 25amps) that could trip the breaker!”
Well I lost track recently, charged too many things at once, and now the breaker has tripped and the one outlet in the living area is no longer working during our cross-Canada boondocking trip.
Anyone recognize this breaker box and know how to reset them? A few have little buttons on the ends which don’t seem to do anything.
I’ve also switched the 12v kill switch off and on a few times to no avail.
LiamG is offline   Reply With Quote
Old 07-11-2020, 05:33 AM   #2
1993 34' Excella
Barry's Bay , ON
And here’s the picture of the box. It’s on the front wall beneath the windows, behind what used to be a couch before our renovation.
Old 07-11-2020, 06:10 AM   #3
2018 25' International
Slidell , Louisiana
The self resetting thermal breakers do self reset, but they generally have to have all voltage removed including any back voltage. So get out the multimeter and determine which one is tripped by testing voltage on both sides of each breaker. Then use the kill switch and verify their is no voltage on the power bus or the breaker on either side. Next test for continuity across the affected breaker using the ohmmeter portion. With no voltage, no heat it should have reset. If it didn't mess with the button and test again. Still nothing? rap on it with a plastic or rubber tool. Still nothing? You will have to replace it.
Old 07-11-2020, 06:13 AM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
LiamG,
Do you own a multi meter or simple 12V test light probe?
Test light is a very basic testing tool and could easily check for 12VDC power coming in and either going thru a circuit, fuse or 12VDC circuit breaker.
Multimeter does more but costs more.
Gary
GCinSC2 is offline   Reply With Quote
Old 07-11-2020, 06:24 AM   #5
dznf0g's Avatar
Oswego , Illinois
I dont believe they are self resetting. Reach your finger back on the ends of the breaker shell. You'll find a little black botton. Push to reset.
-Rich-
Old 07-11-2020, 06:31 AM   #6
GCinSC2's Avatar
Just an FYI about self resetting 12VDC breakers.
Cutaways and a SPARK!
Old 07-11-2020, 08:36 AM   #7
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
If original, those are manually "resettable" breakers. Unless they have been change, there should be black reset button on the end of each breaker inside the panel shown in your photo. Read the third paragraph of section G in your owners manual.
There are larger amperage "auto reset" breakers too, but they are not inside that panel. They are mounted on the wall near the battery box beneath the sofa. This is shown also in section G, noted on the schematic electrical drawing.
These breakers do go bad. I've had to replace a few in my 1999. I now carry spares.
Alan
Old 07-11-2020, 11:10 AM   #8
love nest's Avatar
2019 Nest
Louisa , Virginia
Circuit breakers
There are 2 types of circuit breakers. type 1 that auto reset and type 2 that trip and will not reset unless you completely remove power from it. Try disconnecting the battery (main ground will do it) without the shore line connected and the reconnect. That will reset a type 2 breaker. My Nest has this type.
love nest is offline   Reply With Quote
Old 07-11-2020, 03:30 PM   #9
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
No body has mentioned it, but self resetting circuit breakers are a fire hazard. Under certain short conditions, other than a direct short, the heat build up due to low grade short caused resistance can be dramatic. I had scorching and smoke coming from the TV engine compartment and the TT circuit breaker panel on an SOB. A quick thinking wrecker driver grabbed his cable cutters and cut all positive battery cables (4). Like they say, "Where there is smoke there is fire."
guskmg
Old 07-11-2020, 04:28 PM   #10
1993 34' Excella
Barry's Bay , ON
Thanks for the help. I do have a test light from the previous owner (didn’t know what it was for until now) and every breaker lights up...
So I’m thinking the issue must be with the plug itself or perhaps somewhere in between. In the case of the latter, I’m in trouble, so I’ll see about replacing the plug and hope for the best for now.
Old 07-11-2020, 04:36 PM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Your round plug probably has a fuse in it. Most i have used do. Unscrew the tip and I'm betting a spring and a fuse will fall out.
Old 07-11-2020, 04:59 PM   #12
1993 34' Excella
Barry's Bay , ON
There is no fuse in the round plug. When pulling it out from the wall, the test light probe would light up.
After a bit of poking around, there was a spark when I went to plug the inverter in again and now there’s no power behind the plug. All the breakers are still lighting up, however.
Looks like I’ll be running an extension cord from the bedroom until I can get a pro to look at it.
Old 07-11-2020, 05:57 PM   #13
GCinSC2's Avatar
LiamG,
Well, might not be the result you wanted but you’ve now shook hands with the test light. That’s a good thing. I carry one too. Remember it’s for 12VDC systems not AC.
Gary
Old 07-12-2020, 07:43 AM   #14
love nest's Avatar
2019 Nest
Louisa , Virginia
Circuit breakers
I think I misunderstood your outage problem. you are only having a problem with only 1 outlet if I understand correctly. Usually that would have a auto type fuse on your converter panel. Just a thought.
12v
What would Make the breakers heat up they are really hot to point of tripping when ac Norm excella Batteries, Univolts, Converters & Inverters 7 09-25-2014 02:27 PM
Checking / Resetting Circuit Breaker mizzadventur Electrical - Systems, Generators, Batteries & Solar 3 04-16-2014 06:32 PM
Resetting 12 volt circuit Cathy&Pete Electrical - Systems, Generators, Batteries & Solar 7 10-20-2010 11:15 PM
Resetting circuit breaker? 68Glbtrotter Electrical - Systems, Generators, Batteries & Solar 4 11-02-2005 06:19 AM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 08:46 PM
