Old 08-04-2020, 04:38 PM   #1
2020 20' Bambi
Clayton , North Carolina
Ancillary benefit of portable solar suitcase??
Recently, 2 months ago, purchased 2020 Bambi 20’ with the Zamp 90W rooftop solar panel and the auxillary Zamp port on AFrame. Initially, while still less educated about solar, bought a Zamp 230 W portable suitcase. Then, given the spatial size vs weight (~50lb) decided too unwieldy so sent it back and purchased Zamp 180 W portable (~33 lb ��). Some folks on the form discuss removing the charger control on the portable and wiring the auxillary Aframe port directly to a inside charge controller, same with roof mount. I raised some similar questions with Zamp Ops Manager and he suggested pros and cons. Cons being if you remove the charge controller on portable unit then you are not able to use it to 1) loan to friend who needs to charge trailer battery, 2) cannot use to charge your tow vehicle battery if needed. I thought, yeah. But I ask forum sages, what are some of the other things I can do with the portable solar if I retain as is and keep the charge controller intact? Is there anyway to run other electronic devices? thx, stephen
smsasf is offline   Reply With Quote
Old 08-04-2020, 04:48 PM   #2
2016 16' Sport
Miami , Florida
You could just wire it to bypass the portable controller. Leave the portable in place and reconfigure when the portable controller is needed. Honestly if it were me I’d just leave the controller in place. It’s a bit less efficient but the main time you need it is when the roof panels are not getting any sun.
Shiny16 is offline   Reply With Quote
Old 08-04-2020, 06:11 PM   #3
"Cloudsplitter"
Where does the Zamp plug on the AS go? Directly to the batt's or to a controller?
Old 08-04-2020, 06:52 PM   #4
2020 20' Bambi
Bob, the Zamp plug that is on the AFrame only goes to the battery, not the inside charge controller. The rooftop Zamp (currently one 90W panel plugged into a 3 socket rooftop port) goes to the charge controller. I have read quite a few of previous notes and threads about the inefficiency of a two controller system (the Atkinson supporting rooftop and the separate Zamp controller on the portable). Obviously, confusing.
Old 08-04-2020, 06:56 PM   #5
2020 20' Bambi
But again, if I just leave the portable Zamp 180W as is, with its charge controller, are there uses other than charging trailer battery when rooftop is in shade, charging tow vehicle battery if there was problem or loaning to another camper to charge their trailer battery?
Old 08-04-2020, 08:46 PM   #6
2017 25' Flying Cloud
Raleigh , NC
Well, with my solar suitcase I split the difference. Controller Velcro’s to the trailer near the solar port, and panel sans controller can go wherever. If I had to lend it out, I could give them both. Still too heavy though, so I am going to use it to build a roof mounted system.
JoeHTP is offline   Reply With Quote
Old 08-05-2020, 09:20 AM   #7
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
We run 200w on the roof and 180w suitcase with its own controller through the umbilical. works well no cons they work together. We like the extra because we boondock most of the time and often shade is an issue. the Add suitcase provides that "follow the sun".
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 08-05-2020, 10:18 AM   #8
2019 25' Flying Cloud
North-Central , Florida
following
djbar is offline   Reply With Quote
Old 08-05-2020, 10:51 AM   #9
pjshier's Avatar
2017 27' International
Wasilla , Alaska
options, options
Seems we have a lot going on around here that depends on a battery. And since it is a pain to remove the battery from the: mower, atv, fuel trailer with 12 volt pump... - I use the Renogy 200w suitcase to top off the batteries periodically. Recently, I added 12v LED lights to a remote shed that has a suboptimal fixed panel orientation. The suitcase will be used to top off the recycled golf cart batteries when the solar gain on the fixed panel is low for an extended period.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 08-05-2020, 11:06 AM   #10
"Cloudsplitter"
Then plug your Zamp portable directly into the Zamp connector on the AS, contrary to some advise, the controllers will play well together. One or the other will most likely shut down as the batteries approach full charge.
Old 10-05-2021, 05:32 PM   #11
AptosJo
2014 23' FB Flying Cloud
Aptos , California
AGREE! We run 100w on roof + 180w Zamp suitcase. Works well for us with two Lifeline GPL-4CY AGM 6 v batteries AND Honda 2200i when it's too cold, dark or cloudy (rarely).
AptosJo is offline   Reply With Quote
Solar on the roof and solar suitcase JeffCross 2005 and newer - Bambi all models 17 06-25-2019 01:29 PM
Suitcase solar plug in to onboard solar. HankStarr Generators & Solar Power 10 06-12-2019 09:23 AM
Best 200 W portable suitcase solar setup ??? Milo1952 Electrical - Systems, Generators, Batteries & Solar 17 08-21-2018 09:38 PM
Zamp 160 watt portable solar kit (suitcase) dasams Airstream Classifieds 0 09-01-2017 11:28 AM
Using Two Portable Solar Suitcase Panels tjwoods1 Generators & Solar Power 1 08-29-2017 08:58 AM
