Old 02-12-2025, 10:45 AM   #1
2023 27' Globetrotter
Green Cove Springs , Florida
Airstream battery power green light
On our 2023 27’ Globetrotter the battery power green light near the front door intermittently flashes off and on. Sometimes a it goes off for an extended period. There seems to be no rhyme or reason for when it flashes or goes off for a while. It usually comes back on. The light being off does not seem to affect anything electrical on the trailer as best we can tell.
Does anyone know the reason for this and what to do to fix it so it stays on the way it should?
Does anyone know if the light being off actually affects anything electrical in the trailer.
We normally stay in campgrounds and are plugged in at all times. We haven’t boondocked so don’t know if this would occur when not plugged in. Two Airstream dealers have “fixed” this and it keeps recurring.
DPAS23 is offline   Reply With Quote
Old 02-12-2025, 04:33 PM   #2
2022 25' Flying Cloud
Tualatin , Oregon
The green LED is supposed to blink to advise when the battery level is low. However, most on the forum who experience intermittent blinking have found loose connections at the relay.. Do you know where yours is located? Can you hear it 'click' when you press the green button?
Steve
TitusNW is offline   Reply With Quote
Old 02-12-2025, 04:51 PM   #3
Tualatin , Oregon
If all the wires at the relay are tight (I assume the dealers checked, but... ) you should take the green LED switch out of the cabinet and you'll find a white Molex connector about 6" down the wire, away from the LED switch. Make sure both sides of the connector are pushed securely together.
Steve
Old 02-12-2025, 04:57 PM   #4
waninae39's Avatar
NCR , Ontario
we ignore it
at times we place black tape over it
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 02-12-2025, 04:59 PM   #5
Tualatin , Oregon
Yes, two layers of duct tape at night even after I changed out the resistor on the LED, it's still too bright!
Steve
Old 02-12-2025, 06:19 PM   #6
2024 27' Globetrotter
Olive Branch , Mississippi
I think that intellitec remote disconnect is more trouble than its worth.
os1r1s is offline   Reply With Quote
Old 02-13-2025, 02:55 PM   #7
Thanks to everyone for the information. I know the relay was mentioned by the first Airstream dealer and it was supposedly replaced. Didn’t do much good as the blinking reappeared within a couple of days. I will check the Molex connector to make sure the connections are tight.
As a brief aside. I wish Airstream would fix the little things that seem trivial but are very aggravatiing.
Thanks again for the information.
Old 02-13-2025, 03:05 PM   #8
2023 27' Flying Cloud
Hansville , WA
Ours does the same thing. I put painters tape over it and ignore it. I seldom turn the switch off as we are usually plugged in at home or on the road.
Big Red1 is offline   Reply With Quote
Old 02-13-2025, 08:16 PM   #9
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
Air Boards
Maybe this is why the AirBoad Shop has designed a cover for that light.
https://airboardshop.com
https://airboardshop.com/products/light-blocker
https://airboardshop.com/cdn/shop/vi...012576.mp4?v=0
Life is a Highway is offline   Reply With Quote
Old 02-14-2025, 09:48 AM   #10
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
It's aggravating, but if nothing else works I wouldn't worry about it since I have yet to figure out what good that switch does. It does not disconnect the batteries completely from all DC loads, only the ones in connected in the fuse box. The CO detector and the inverter standby still will drain the batteries eventually. We like our 12V frig running while in the road, so it's no good at disconnecting a light or something that got left on accidentally. If there's a realistic scenario where it's useful I'd like to know.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 02-14-2025, 12:22 PM   #11
Tualatin , Oregon
I decided to move the converter charge line from the "battery side" to the "house side". I'm lucky and have shore power available in storage and my purpose was to stop continuously charging the batteries but have power available in the trailer.
Other than the CO/propane sensor I have a TPMS repeater and a Renogy blue tooth battery repeater connected to the batteries. The parasitic load is +/- 0.7amp daily.
I watch the battery charge drift and occasionally reconnect the batteries to confirm the converter is putting out amps, the batteries are accepting the charge and the Renogy phone app is working. I really rely on the Renogy when camping and with the converter charge line moved I can confirm all before I go out on a trip.
I will admit the green LED now stays lit whether the relay is connected or not - I have not spent any time sorting that out. The 47k ohm resistor just knocks the brightness down to tolerable.
Steve
ID:	450967   Click image for larger version
Name:	Disconnect Switch Showing Resistor.jpg
Old 02-19-2025, 09:41 AM   #12
2022 23' Flying Cloud
Watsontown , Pennsylvania
We had the blinking light on our 2022. It was after we drove through a torrential downpour for hours. Water had gotten into our battery compartment and into the RJ45 connectors on our batteries. Dried them out and it was fine.
When I hit that switch, on our AS, the gas alarm goes off (turns off). I thought that was supposed to be wired to never go off.
ricjones is offline   Reply With Quote
Battery disconnect green light DeltaRon 2016 - Current Flying Cloud 26 06-05-2024 07:08 AM
Green Light on HDMI plate in 2023 airstream MRA Electronics & Connectivity 3 12-20-2023 04:15 AM
Flickering Green Light on Intellitec Battery Disconnect Switch Tyler2you Electrical - Systems, Generators, Batteries & Solar 2 10-24-2022 12:54 PM
green blinking light in parallax power box Peggy Raffer Electrical - Systems, Generators, Batteries & Solar 0 03-13-2017 06:34 PM
Help! After storage, no battery power but Monitor shows green barrettjl Electrical - Systems, Generators, Batteries & Solar 6 05-28-2013 10:13 PM
