easystart install
Just finished my micro air easystart install. If you are at all handy, it is fairly easy, especially with online instructions. One caveat, after I did my install and started the AC the first time I got an error code on the thermostat. I turns out (after some consternation and research) that the AC control board has a number of DIP switches which are very easy to disturb when wiring the run capacitor. If these are not set properly or changed, the system will not work. So I had to disassemble the AC and reset these properly. If you are doing this install, note the switch positions before you begin and be careful not to change them.
Everything running well now, it is a important upgrade.
