RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-06-2019, 08:27 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
added front jack cut-off switch
i added a 3rd power cutoff switch to our trailer
  1. to the solar panel
  2. between the 12V 100% on BUS BAR and the 12v controlled devices BUS BAR
  3. to the front jack trailer mover power connection
the 3rd connection ensure that no one plays with the jack as well as ensures that the jack light, if left on, will go off when we shut the switch at night or when we are away
you can see the switch in the bottom right corner of the schematic attached
as well the switch keys can be pulled out , to prevent accidental turning or breaking of them when getting into bed.
the panel is near the floor between the sink and bed on the lower left side of the bed.
Name:	AS22FB- power DC and AC-V7a.jpg
ID:	339942   Click image for larger version
Name:	new jack swicth.jpg
waninae39 is offline   Reply With Quote
Cut-Off Switch for House Battery: Install on the Negative Cable or Positive Cable? Searching Batteries, Univolts, Converters & Inverters 27 04-18-2020 07:08 PM
Does this added side trim indicate shell was taken off jwschnettl General Repair Forum 1 12-15-2018 07:57 PM
Atwood Thermal cut off switch terricrowe26 Water Heaters, Filters & Pumps 8 10-01-2018 03:47 PM
Laser cut ignition (key) switch tool. RBonney Classic Motorhomes 5 08-20-2016 07:39 AM
How does water pump cut off? 26.982 amu Water Heaters, Filters & Pumps 5 02-08-2006 07:40 AM
