RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-15-2018, 05:16 PM   #41
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by macm91 View Post
Hooked up to shore power. Last night Air went off, we weren't there, and we had an E7 error code. I turned it off. turned off all circuit breakers and pole breakers. Went back and started tjurning everything on,,,, no AC power anywhere inside.
Good power coming from outside.
Main GFCI breaker on panel will not reset to on position.
2017 Flying Cloud 28.
Ideas?
Ani deas on the circuit breaker issue i posted?
Does your trailer have 30 amp or 50 amp service?
If it has 30 amp, you should have a transfer switch to prevent the second inlet from being energized when connected to power. That transfer switch has been known to fail in the past. Try unplugging from whichever inlet (front or side) you are connected to, and plug it in to the other inlet, and see if it starts working.
Old 07-15-2018, 05:23 PM   #42
2002 30' Classic
Ocala , Florida
Did you push GFI breaker hard to off position before tryi g to reset? Must do to turn back on.
Bigdaddy_2 is offline   Reply With Quote
Old 07-15-2018, 05:24 PM   #43
2019 23' Flying Cloud
Kure Beach , NC
Switched input location from side to front.. no change....breaker will not reset when power is off,,,,,
macm91 is offline   Reply With Quote
Old 07-15-2018, 05:26 PM   #44
Kure Beach , NC
No dice on circuit breaker without power, As is there is no ac power to trailer,
Old 07-15-2018, 05:52 PM   #45
DKB_SATX's Avatar
Alamo Heights , Texas
If the breaker won't reset when your trailer is not plugged in, the breaker is toast. Get a replacement breaker.
— David
Carefree Roadside & Rear Window Awning Arms & Rollers For 1976 31' Airstream Sovereign mrnos44 Airstream Classifieds 0 08-23-2016 08:08 PM
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 05:25 PM
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 09:25 PM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 09:37 PM
