Old 05-30-2019, 07:48 PM   #1
2019 27' Flying Cloud
2004 25' Safari
Williamsburg , Virginia
Absorption vs Float
Camping this week in new FC27, 50A, solar, have AGM batteries, everything is stock. At current campsite, am using 30A receptacle. Battery voltage on the SeaLevel II is reading 13.2V, which the owners manual indicates is the Float charge. Even when turning things on such as lights, fans, etc, it remains at 13.2. When drawing amps, I thought it should go from Float to Absorption which should indicate 13.6V. At other times and places I've seen it in Absorption, but not here. Any thoughts?
AgBullet is online now   Reply With Quote
Old 05-30-2019, 08:41 PM   #2
dznf0g's Avatar
Oswego , Illinois
Unless you are drawing current at a greater rate than the converter is capable of producing, the battery is not being drawn down. Therefore the state of charge of the battery will demand only float.
-Rich-
Old 05-31-2019, 04:36 PM   #3
2004 25' Safari
Now at a 50 amp site and the charger is in absorption per normal, all power usage the same. Still curious to know why it didnít do this at previous site, but thanks for your input.
Any charger around with a high voltage absorption phase? tvoneicken Batteries, Univolts, Converters & Inverters 6 12-13-2017 07:17 PM
Electric heating element for Norcold Absorption Refrigerator Carol in Air Refrigerators 3 08-21-2014 07:39 AM
New atwood gas/absorption fridge lewster Commercial Listings 17 02-25-2012 07:59 AM
First Big Trip, First Time Float Tubers :eek: Rhodie On The Road... 14 08-11-2005 02:18 AM
Anyone discover a fuel friendly float setting? IPM Mechanics Corner - Engines, Transmission & More... 18 05-11-2004 11:04 AM
