Old 04-02-2018, 03:45 PM   #1
BracketRacer's Avatar
1999 35' Cutter Diesel Bus w/slide
Boise , Id
'99 Cutter dash issue
First post. I'm hoping there is not a go to the newbie thread person here!
Bought a 99 Cutter 35 footer with a slide. Everything is good and works well. TV and related components aren't 100 per cent but I an deal with that.
Question I have is dash gauges intermittently don't read properly. Example battery gauge shows 8 volts and turns the light on and fuel level says full all the time. Now and again they all work fine. Kind of an annoyance but hoping someone here has had this issue and can provide a solution.
Thanks.
BracketRacer is offline   Reply With Quote
Old 04-04-2018, 12:23 PM   #2
Boise , Id
Bueller?
Old 04-04-2018, 12:55 PM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Sounds like a ground issue with your gauges. That's where I would start anyway. Bad ground can cause so many strange problems. You can start at either end, the batteries and motor straps or tracing you dash ground and work back.
mayco is offline   Reply With Quote
Old 04-05-2018, 07:31 PM   #4
Byron Center , Michigan
Agreed.
YippieKiYa is offline   Reply With Quote
Old 04-05-2018, 11:24 PM   #5
Boise , Id
Battery bridge cable was loose. Fixed!
1999 Cutter, dash AC/heat issues Moorchen Airstream Motorhome Forums 6 12-16-2017 06:23 PM
'98 Cutter Dash Air Charge Koheleth Mechanics Corner - Engines, Transmission & More... 2 03-30-2015 07:50 PM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-22-2011 07:30 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-11-2011 11:10 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-01-2011 10:40 AM
