Old 10-14-2021, 09:10 AM   #1
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
70's Land Yacht Electrical corner re-layout
My '73 Globetrotter had the "Land Yacht" rear bath layout, where the tub/shower lay in the street side corner, the sink stretched across the back, the toilet was in the near middle of the rear facing forward, and the curbside corner was occupied by a closet/wardrobe. The battery was installed in an exterior battery box that was mostly below the floor and under the above mentioned closet and kitchen. The univolt was mounted on the floor, and was covered by a false bottom in the closet. The AC breaker box was mounted on the wall in that closet.
I am putting it all back together after a lengthy rebuild, and was planning to reassemble similar to how it was set up originally, with some modifications. I have gone to a larger AGM battery, which will no longer fit in the original battery box, so have repurposed the battery box to be an outdoor shower, and am planning to put the battery inside, either under the closet false floor or under the kitchen (at the expense of some storage space). The converter will be under the false floor, and the AC and DC breakers/fuses will be on the interior wall of the closet.
I am having a bit of trouble piecing this together without it looking like an after though/act of desperation. Anyone out there gone through roughly the same process and have some inspirational advice/pictures to share?
thanks!
Old 10-14-2021, 02:34 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
If you can do without a closet in the bathroom, I'd take it out, move the sink to that side (if not the fiberglas one that attaches to the tub. That puts the toilet in the middle and could be angled a little to the side if desired. That's what we did, but we were going from a shower with toilet to a tub with hand held shower.
Name:	Original Bath closet.jpg
ID:	406253 Click image for larger version
Name:	Original shower with toilet.jpg
ID:	406255 Click image for larger version
Name:	Bath Cabinet.jpg
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-14-2021, 05:30 PM   #3
Belegedhel's Avatar
Houston , Texas
I'm quite married at this point to the layout of the bathroom being as described above, but your post does make a good point, which is that one of the primary functions of the closet is to hide the vent pipe from the black tank, and the ugliness of the electrical wires sprouting from the wall (plus the converter, top of battery box,etc.).
I could eliminate the closet, in terms of a completely enclosed space, and crowd most of the electrical stuff into the back corner... Not sure the back corner is a good place for that heavy (110AH) battery.
Have a look at the pic below, the jumble on the left side of the pic is what I am trying to make nice.
Old 10-14-2021, 08:00 PM   #4
1973 23' Safari
Arroyo Grande , California
We have the same layout in our 73 Safari and chose to retain the original look bot hereís what we built for our closet.
StevenD is offline   Reply With Quote
Old 10-14-2021, 09:00 PM   #5
Belegedhel's Avatar
Houston , Texas
So are you completely eliminating storage in the bathroom, or is that mission control center behind a wall that has yet to be put in place?
thanks!
Old 10-15-2021, 09:08 AM   #6
1973 23' Safari
We built this above the original battery box so we did not give up much floor space and with the closet door closed, you canít tell it is there. We located 2 additional agm batteries under the bed and vented them thru the existing battery box.
ID:	406306   Click image for larger version
Old 10-16-2021, 10:26 AM   #7
Belegedhel's Avatar
Houston , Texas
Your electrical system seems a lot more complex than mine, for a trailer that is only slightly larger. Can you elaborate on your set up? Do you have solar involved as well? Do you have an inverter? I can see that you have AC and DC breakers, but also many cut-off switches.
thanks!
Old 10-18-2021, 08:40 AM   #8
1973 23' Safari
Admittedly this was overkill. No inverter but the converter and ac surge protector are mounted under the three red cutoff switches, which is one for each battery. The yellow switches also function as circuit breakers, one wired for solar, another for the tow vehicle charge line and the 100 amp one that functions as a main breaker for the dc system. It all started because I wanted to add an ac circuit for a microwave and eliminate the fuses when the Univolt went away. I stumbled onto a Bluesea catalog and away I went.
Old 10-18-2021, 09:46 AM   #9
57Vintage's Avatar
1958 26' Overlander
Images: 22
Blue Sea can lead to complexity if you don't maintain a KISS approach.
Name:	Shore power main panel.jpg
ID:	406549 Click image for larger version
Name:	Electrical Controls.jpg
Harold & Rebecca
Our thread:
Old 10-18-2021, 09:48 PM   #10
Belegedhel's Avatar
Houston , Texas
Yep, I am definitely trying to keep it basic. Would like to get the AC and DC fuses/breakers out where I can reach them, and my battery cutoff switch and Sealevel gauge. I originally bought a new DC fuse block, but now am looking at the combined AC and DC control panels that are available in an effort to make the AC box look less like something that ought to be hidden.
Several Items from 1971 Globetrotter Land Yacht 21' Double layout - Tennessee HumbleRumble Airstream Classifieds 6 09-06-2020 03:34 PM
New Electrical Layout - 1967 Safari schnetzer Electrical - Systems, Generators, Batteries & Solar 0 07-01-2015 11:06 AM
74 Airstream Overlander Land Yacht F131 Land Yacht eBay Watch Airstreams on eBay 0 04-02-2010 02:50 PM
Electrical layout hampstead38 1965 - 1969 Overlander 18 08-18-2009 09:09 PM
31' airstream land yacht rare rear bedroom cabin layout eBay Watch Airstreams on eBay 0 03-08-2009 04:50 PM
