Old 12-09-2022, 06:10 PM   #1
1961 16' Bambi
1963 16' Bambi
Greenville, MS , Greenville, MS and Memphis, TN
Send a message via Yahoo to highcotton
‘70 Overlander
I recently purchased a completely restored a 1970 Overlander. I want to completely do away with propane. I want to get an electric furnace to replace the propane one I would like for it to go in the space where the propane is located. Any suggestions? I am deadly afraid of propane.
highcotton is offline   Reply With Quote
Old 12-09-2022, 06:34 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Welcome to these Forums. I have a 75 Overlander that I renovated. Since you live in the southern part of the country, I wonder if you can get buy with just 120v space heaters. Two of them may do the trick. But they won't do it in 30f degree weather. I think the original Overlander furnace was 30k btu. That is a lot of heat. Now add an electric stove, electric water heater and a electric fridge and you are going to need a lot of amps. Propane is very energy dense compared to 120v electricity. And it has a very good safety record.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
dbj216 is offline   Reply With Quote
Old 12-10-2022, 11:48 AM   #3
1961 16' Bambi
1963 16' Bambi
I do not want to use space heaters if at all possible. The unit I have has a domestic a/c. On the controls, it has on the switch an “option” for heat. Being a newbie, does that mean the Dometic unit has heat built in? That would solve my problem, if it does.
Highcotton - Mike
The closest distance between two points is usually under construction.
Old 12-10-2022, 04:08 PM   #4
1988 32' Excella
Robbinsville , New Jersey
That means it might have heat built in. You could just try it, with it saying heat option it should mean heat strip, not heat pump. The heat strips came in 500watt, 1000watt or 1500watt and were optional, so at most the same 5000 BTUs of a portable heater and noisy.
Wazbro is offline   Reply With Quote
The Overlander :: 1964 Airstream Overlander Janet H Airstream Registry Discussions 3 08-20-2018 10:12 PM
Overlander Land Yacht International :: 1964 Airstream Overlander Land Yacht Internati overlander64 Airstream Registry Discussions 2 01-27-2018 06:28 AM
Land Yacht Overlander :: 1968 Airstream Overlander Von Moritz Airstream Registry Discussions 0 10-10-2013 08:29 AM
Overlander International :: 1973 Airstream Overlander rmoores Airstream Registry Discussions 0 01-31-2012 10:46 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
