Old 07-12-2020, 08:45 AM   #1
1970 27' Overlander
Attica , Michigan
7 pin question
I have a 1970 Overlander that I'm still restoring, I'm just wondering how to hook up the 12 volt power coming from the TV. Trailer has a solar system and lithium batteries. Not sure if I should just connect that directly to the battery bank or should it go to 1 of the charge controllers, and if so which one. Thanks
Myelfself is offline   Reply With Quote
Old 07-12-2020, 10:46 AM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Hard to make suggestion without knowing more about components in your system. Where does the power from the TV go now? Does it have anything to regulate voltage from the TV, such as a DC-DC Converter?
Assuming you have some type of separate controller for the solar panels
Photos and a circuit diagram would help a lot.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 07-13-2020, 02:40 AM   #3
1970 27' Overlander
Attica , Michigan
The 12 volt power from the TV is not currently connected to anything. I'm not sure how power to that wire is regulated if at all. Solar power goes thru a Victrom solar charge controller.
7 pin to 4 pin - Jeep wrangler 42570 Our Community 6 09-08-2010 09:44 PM
9 pin to 7 pin conversion ck21084 Electrical - Systems, Generators, Batteries & Solar 4 06-10-2010 02:58 PM
6-pin connector to AS 7-pin eugnicfrlie Towing, Tow Vehicles & Hitches 6 04-15-2009 10:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
