Originally Posted by Todd G
All,
We are planning on installing a 50AMP outlet at our home. The issue is the location of the outlet will be about 80-90 feet away from our parking spot. Is it Ok to daisychain multiple 50AMP cords to reach the outlet??
Understanding there are many reasons why a power line cant be properly trenched in to support a RV Service outlet closer to the parking lot. Just be sure they are the right reasons. Before investing in the daisy chain, consult with the licensed electrician who will be installing the 50 Amp outlet at the house, maybe even get a quote for a trenched line out to the parking lot.
So if you decide to proceed ahead with the daisy chain plan, use electrical tape to seal the connections from water. Some will also recommend that the connections be elevated off the ground. Depending on the quality, size and length of the daisy chained cords, you may experience voltage drop, which will reduce the amount of power available to run everything in the trailer.
Protect the cord from mowers, mark with survey flags or something. Do not place the cord across the driveway where it will be run over. Inspect regularly for damage, varmints will eat the insulation off.
