Old 05-24-2021, 04:05 AM   #1
2021 27' Globetrotter
Daytona Beach , Florida
50A Smart Plug to 15A / Short Dog Bone
Does anyone know where to find one? I want to use this to plug my camper in while storing it. There is a link on here that take me to most of the major marine supply houses, but I found nothing there either. Thanks for the help.
nitzo is offline   Reply With Quote
Old 05-24-2021, 05:07 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
https://www.amazon.com/Mighty-Cord-A...850806&sr=8-15
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-24-2021, 06:02 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
You might find something like this a bit easier to use:
https://www.amazon.com/Camco-Dogbone...1854002&sr=8-6
I've tried both styles - the one linked to earlier and the kind with the short cord between the two ends. The one-piece adapters always seem to me to put too much weight on the 15-amp outlet for the thing to stay plugged in.
This one has a right-angle plug on the 15-amp end, so it makes it easier to keep plugged in and takes some of the torque off the outlet.
Richard
11018
richard5933 is online now   Reply With Quote
Old 05-24-2021, 06:52 AM   #4
Sumterville , Florida
Search for C50044L515P.
Out of stock at eTrailer. They are pricey, so you may want to use your OEM cord with the traditional dogbone at the 15a outlet as the more economical solution.
SVTOTEM is offline   Reply With Quote
Old 05-24-2021, 10:12 AM   #5
1972 Argosy 24
Houston , Texas
Originally Posted by majorairhead View Post
This one works with any regular extension cord, so you don't need to pull out the big heavy 50amp cable. This adapter assumes you have the round twist-lock socket on the trailer...
johndpolk37 is offline   Reply With Quote
Old 05-24-2021, 10:32 AM   #6
Airstream Trippin
2020 33' Classic
Livingston , Texas
Get it directly from Airstream. They aren’t that expensive.
Gigler is offline   Reply With Quote
Old 05-24-2021, 10:51 AM   #7
2022 Atlas
Homosassa , Florida
Smartplug is the only place I've seen one. West Marine may have them but I would go directly to smartplug.
Tater is offline   Reply With Quote
Old 05-24-2021, 11:06 AM   #8
1988 32' Excella
Robbinsville , New Jersey
He clearly stated he does not have the round twist-lock socket on the trailer.
He has a SMART PLUG, this is what he wants.
https://smartplug.com/product/50a-sm...lug-connector/
Here's a link to the plug the OP could use to make one. https://www.bestconverter.com/50-Amp...F50_p_737.html
Old 05-24-2021, 12:41 PM   #9
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Before I added more solar to the TerraYacht I would run 15 or 20 amp 120vac for maintenance power, just necked down the standard 50 amp to 30 (adapter came in my rv from the PO) then 30 to 15. I used a short 6' cord, 12 gauge, to reduce pull strain where I am plugged in. The adapters were already in the compartment but direct from SmartPlug is a better approach.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
TerraYacht is offline   Reply With Quote
Old 05-24-2021, 01:00 PM   #10
2019 30' Classic
2021 Atlas
Charlotte , North Carolina
I got a Smart Plug brand one from a marine store. Works perfectly. Also use it to hook to the generator for a quick charge. However, I also got a small 15A surge/power protector with open ground, neutral, low volt, etc shut off. Got that from Amazon. I can get the link if anyone wants it. Better than completely unprotected and the surge/power protector I have is 50A with the regular 50A plug. So to get rid of the heavy plug, I got the cheap 15A protector.
LilPeanut is offline   Reply With Quote
Old 05-24-2021, 01:11 PM   #11
2021 27' International
Raleigh , North Carolina
Etrailer has the Smart Plug adapter but they are on backorder. They are scheduled to ship next week.
BT2513 is offline   Reply With Quote
Old 06-03-2021, 08:12 AM   #12
2019 30' Classic
Belen , New Mexico
Rather than lug the power cord out when storing, I just bought and extra smart plug and a standard 25 foot extension cord. It’s about the same weight as a dogbone and easy to store. Less appealing to a thief and a whole lot easier to deploy than the regular power cord.
I just cut the socket end off of the cord and install the smart plug on it
Ephraim is offline   Reply With Quote
Old 06-03-2021, 09:35 AM   #13
2019 30' Classic
Belen , New Mexico
Picture of cord
Old 06-06-2021, 03:57 PM   #14
I like this idea. Do I dare ask how to wire it?
Old 06-06-2021, 11:31 PM   #15
2019 30' Classic
Belen , New Mexico
Its really easy. The plug comes with written instructions on how to wire it. the only caveat is if you are wiring a 50A plug, you have to wire the hot wire (black) to both legs of the plug. If you are wiring a 30A plug, one wire to each leg.
the plug makes it easy. the brass screw holds the black (or red) wire. the silver screw holds the white wire and the green screw holds the green wire.
Old 06-09-2021, 10:25 AM   #16
silverbacksurfer's Avatar
2005 25' International CCD
Glendale , California
15 amp smart plug pigtail
I bought the smart plug female side that plugs into the trailer and just put a new 15 amp extension cord on it and made my own I never pull out the Anaconda cord at an RV park cuz it's too much hassle I pull out my homemade 15 amp extension cord one and just plug it in they have just a female ends on Amazon
silverbacksurfer is offline   Reply With Quote
Old 06-09-2021, 10:27 AM   #17
Yeah what all those guys said before me I didn't read those oh well that's what you need to do make your own
Old 06-09-2021, 10:47 AM   #18
2021 19' Caravel
Wilderness , MO
Can you connect the 50 to a 30 adapter, then connect the 30 to a 15 adapter? I connect our 30 to a 15 adapter whenever we're home.
Or maybe I'm missing something in the conversation. If so, then, as Gilda Radner would say, "Never mind."
jfreeham is offline   Reply With Quote
Old 06-09-2021, 10:48 AM   #19
RJ Dominic, 1975 Soverign
Flat Creek's Avatar
1985 34' Sovereign
Potsdam , New York
Send a message via AIM to Flat Creek
Both Gander RV and Amazon have them with the 90 degree handle to make it easier on the twist lock. Yeah they are pricy but
Flat Creek is offline   Reply With Quote
Old 06-09-2021, 11:32 AM   #20
Smart plug brand connector versus Factory twist-lock connector
I think the original post is referring to the Brand Smart plug the orange new non Factory add-on vs the twist lock factory connecter and what he wants to do with it
Use of PI 30A bms in 50A plug kmrice Batteries, Univolts, Converters & Inverters 1 03-15-2021 03:47 PM
Was I just a bone head? sbowman 2016 - Current Classic (all lengths) 16 10-21-2017 10:35 AM
Washin the dog, washin the dog... J. Morgan The Pet Forum 0 05-02-2016 09:18 PM
fish bone antenna Gearheart Audio, Video & TV 3 10-13-2014 01:20 PM
First dog in AS - how do you eliminate that dog smell? Whirlaway The Pet Forum 42 03-22-2010 06:54 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
