Old 04-26-2020, 10:08 AM   #1
2019 27' International
Niederwald , Texas
50A cord length
Does anyone know how long the 50A shore power cord is that ships with a 2019 Int'l Serenity 27FB??
ArtBro is offline   Reply With Quote
Old 04-26-2020, 12:13 PM   #2
Mollysdad's Avatar
It doesn't say in the specs, but I always thought they were 25'-30'.
I've never needed an extension. (yet)
But after you wrestle that Anaconda a few times, you'll be replacing it with something more suited to humans, like this from e-trailer.
"The Mighty Cord"
Old 04-26-2020, 12:19 PM   #3
2017 28' International
Jim Falls , Wisconsin
They are about 30’. I bought a 15’ because the 30’ is a beast to get in and out, and in most cases you don’t need the 30’. I do travel with the 30’ to use if necessary. The 15’ is far far easier to use and if you can I would get one.
Daquenzer is offline   Reply With Quote
Old 04-26-2020, 01:02 PM   #4
egraham's Avatar
2016 28' International
Birmingham , Alabama
I also bought a 15 cord and a 15 extension cord. I have never had to use the extension. The monster that came with my Airstream stays at home.
egraham is offline   Reply With Quote
Old 04-26-2020, 01:25 PM   #5
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I dont understand why AS provides that monster power cord. Its virtually impossible to use, especially when cold.
Old 04-26-2020, 02:20 PM   #6
2018 25' International
Slidell , Louisiana
What they all said. I still use mine. It is 35 ft. Going to order a shorter one now.
Old 04-27-2020, 07:47 AM   #7
2019 25' Flying Cloud
Houston , Texas
"The Mighty Cord"
Is that 90 degree angle worth paying extra for over the regular cord?
DCPAS is offline   Reply With Quote
Old 04-27-2020, 08:04 AM   #8
Mollysdad's Avatar
IMO, yes. But I'm not sure it's extra. The 90 deg allows the weight of the cable to hang straight down, thus removing the load off the Airstream connector. Also it reduces the chance of bumping it as you walk by, and finally, it looks cool.
Oh, wait. Were you thinking the 90 deg. was the only difference over the stock cable? Nay, nay. The OEM cable that comes with your Airstream cannot be easily coiled and it weighs a ton. If you can coil it in a 3' ring, you're doing good. It's hard to store.
The "Mighty Cord" and others similar are MUCH more flexible. They can easily be coiled to 18" and stored in the outside locker. That was the main reason I bought it, not just for the 90 degree connector.
Old 04-27-2020, 10:37 AM   #9
Houston , Texas
No. I was all in when you said there was a reasonable cord. The stock one is awful, but I didn't know until now that there were better options. I found that Mighty Cord in both a regular and a slightly more expensive 90 degree version.
Old 04-27-2020, 11:27 AM   #10
Hans627's Avatar
IMHO it is worth the difference in cost, about $10 more.
Old 04-27-2020, 11:30 AM   #11
Mollysdad's Avatar
Having had other 50 amp cords, I knew the OEM one was uniquely bad.
The guys at e-Trailer actually went into the warehouse to see how tightly it coiled. They reported they did 16". I think Camco makes one also.
Since I've opened the door, I also have a 30 amp cord with a 50 amp female. If I have only 30 amp power, I use that one. It's like a feather compared to the stock AS cord. (My storage room has 30 amp, so I haven't lost my mind totally.)
Old 04-27-2020, 12:52 PM   #12
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
The Valterra Mighty Cord that was pictured from etrailer, it that the 25' cord? I was looking for a little shorter, but since it is much more manageable, 25' will work. The first year we had our AS, I was fine with the factory cord. The second season, I tolerated it. Now I'm just tired of fighting with it. Thanks for the info.
StuartsDad is offline   Reply With Quote
Old 04-27-2020, 01:16 PM   #13
Houston , Texas
I was hoping to find a 15 ft plus 15 ft extension, but in the red handle Valterra cord, it only comes in 25 ft. At least that is what the manufacturer's website says.
Old 04-27-2020, 04:23 PM   #14
egraham's Avatar
No sure but I think I bought my 15 foot cord from Camping world.
Looking for a Trailer 50’s-60’s-70's length 16′ to 22′ Laurenicod Airstream Classifieds 0 12-19-2016 02:04 AM
Using a 30A cord with a 50A shore power terminal thebreezeman Electrical - Systems, Generators, Batteries & Solar 46 02-08-2015 07:12 PM
2015 50A Power Cord Stiff and Near Unusable 2012FB 2009-2015 Flying Cloud 35 01-09-2015 04:34 PM
30A to 50A cord? Bambi_Bandit Electrical - Systems, Generators, Batteries & Solar 9 02-04-2009 03:57 PM
