Old 02-28-2024, 05:12 AM   #1
chugchug's Avatar
2018 25' International
Belmont , California
30 Amp Inlet Meltdown
This is the second time this happens. About 3 years ago the rear inlet 30A overheated, and I replaced the plug at the end of the power cable. I used mainly the front inlet since then. Now it happened on the front inlet. The plug got hot enough to melt the plastic and the blade moved to the point that it makes no contact at all. Now both inlets and the plug need to be replaced.
My question is did anybody find a reliable 30A inlet that is also reasonably priced? I looked at the SmartPlug option, but they are too expensive. I suppose being non-standard with no UL approval they have to carry high priced insurance. There are plenty of options on Amazon, but none of them discussing overheating problem. I suppose 30A connection is not something that anybody would expect to overheat.
I am looking at this inlet from Amazon. Marine grade, and indicator. Is there enough room to use this for the front inlet as well?
https://www.amazon.com/Furrion-43186...ef_=ast_sto_dp
ID:	441477   Click image for larger version
chugchug is offline   Reply With Quote
Used Marinco 30 amp inlet and Marinco Cable/Phone Inlet montanablue Airstream Classifieds 0 11-16-2018 03:09 PM
Battery Meltdown! wulfraat Batteries, Univolts, Converters & Inverters 32 10-14-2018 12:17 AM
Michigan Having a Meltdown??? wheel interested Off Topic Forum 33 09-13-2009 03:05 AM
Electrical Meltdown Fletch88 Electrical - Systems, Generators, Batteries & Solar 6 07-04-2009 11:55 PM
