RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-13-2018, 12:32 PM   #21
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
Yamaha
The Yamaha EF 2400ISHC is the generator I use to run my AC. I don't know why more people aren't using this. The weight and cost similar to the Honda 2000. But, it has a built in capacitor that stores high voltage for the intermittent high current draw of an AC motor starting up. No need for 2 Honda 2000's or a 3000 watt generator. The Yamaha weighs 76 lbs, just slightly more than the Honda, and fits in my pickup bed. It is converted to propane now. I used a Honda 3000 before and there is no difference in AC performance. The Yamaha is rated at 2,000 watts continuous and that is enough for the AC an misc. small loads.
https://www.yamahagenerators.com/EF2...ef2400ishc.htm
50 AMP Dual AC
AM Solar 570 watts
2 Golf Cart 6V Batteries
2012 GMC Denali HD Duramax
Pro Pride hitch
rp709 is offline   Reply With Quote
Old 06-22-2018, 12:53 PM   #22
2011 22' Sport
Portland , Oregon
To be fair, when you say "weight is similar" it is actually 60% increase in weight over the EU2200i, which is a dry weight of 46.5# and the EF2400ISHC has a dry weight of 75#. If we look at this from "safe to handle" guidelines from OSHA, the EU2x000i fits within the guidelines for a single person to lift (<50#), while the Yamaha absolutely falls into the "use two or more people to lift" category.
SilverHouseDreams is offline   Reply With Quote
amps required to run Dometic A/C Barry Parkof Furnaces, Heaters, Fireplaces & Air Conditioning 19 05-28-2016 07:24 AM
30 amps vs 50 amps @ Rv parks ColoradoLady Electrical - Systems, Generators, Batteries & Solar 18 07-25-2015 08:59 AM
Going from 50 amps to 30 amps for a 23FB KWN306 Electrical - Systems, Generators, Batteries & Solar 1 01-28-2015 12:12 PM
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 11:32 AM
15 Amps vs 30 Amps billida1 Electrical - Systems, Generators, Batteries & Solar 8 10-01-2010 09:37 AM
