Old 10-22-2024, 09:33 AM   #1
BML
2024 28' Pottery Barn
FRESNO , CA
20/30 amp shore power to 50AMP AS
So; still learning, but if I have a distance to cover that my 25' 50AMP wont make.... lets say I have a 30 amp pedestal, do I "dogbone" (30 to 50) then attach my surge protector then my 50 amp cord? Or let say its a 20 amp pedestal - dogbone 20 to 30 then dogbone 30 to 50 , then surge protector then my 50 amp cord.
**Surge protector is a HUGHES 50 amp -POWER WATCHDOG
I've only had a few trips under my belt and have all been with 50amp pedestals, but I now I'll expanding my trips and be prepared/knowledgeable.
BML is offline   Reply With Quote
Old 10-22-2024, 09:36 AM   #2
2019 25' Flying Cloud
Houston , Texas
You have it right except I bought a 15/20amp to 50amp to eliminate one dogbone. When the trailer is in storage, which is 15amp, I just use a surge protector and regular extension instead of the big cord and EMS.
DCPAS is offline   Reply With Quote
Old 10-22-2024, 09:57 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If your EMS is a 50-amp model, then yes, the dogbone goes between the pedestal and the EMS.
Carry a selection of 90-degree dogbone adapters so you only have to use one, as mentioned earlier. The 90-degree adapters are much less likely to be pulled out by the weight of the EMS.
We also carry a length of 1" flat webbing strap which we use to strap the adapter into the pedestal to make sure it stays put. There is a bunch of weight hanging in it so it's good to make it secure.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 10-22-2024, 11:16 AM   #4
BML
FRESNO , CA
Dang, you guys are the best....I told my wife this morning i wanted to be clear on this and I'd ask Air Forums and get the answers by lunch.... you all never disappoint and thank you very much!!1 I currently have a 20 to 50 dogbone and 30 to 50 in my toy box so I think I'm good to go.....I think I'll get the 90 degree dogbones, they are cheap .. I like that idea
Old 10-22-2024, 01:43 PM   #5
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Straight through plug adapter
BML, you may want to check out the Progressive Industries 30-50A plug adapter vs. a dog bone for your EMS. This helps keep the WatchDog off the ground.
I used the dog bone when we had a Progressive 50A EMS before finding this straight through adapter. I use it now at home where we have a 30A shore power outlet.
ID:	448405   Click image for larger version
ID:	448407   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 10-22-2024, 04:18 PM   #6
2023 25' Globetrotter
Ancient City , Florida
https://www.bestconverter.com/50-to-...lug_p_535.html
G8trwood is offline   Reply With Quote
50Amp 125/250V SmartPlug Shore Power RV/Boat Inlet and Plug - New York Silver.Cabin Airstream Classifieds 0 07-01-2022 10:57 AM
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 23 05-03-2022 05:29 PM
Shore Hookup at Home? 30amp? 50amp? juddf Electrical - Systems, Generators, Batteries & Solar 43 07-24-2021 04:31 PM
Converting 50amp power source to 30 amp trailer danandmimi On The Road... 19 09-29-2016 10:30 PM
